09-26-2007, 12:01 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: In Think
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | Chinese Ztc Zt303 100% Procces Then Phone Off PHONE 100% PROCCES THEN OFF. I DONE FLASHING & FFS FORMAT. BUT PHONE NOT NORMAL ON PLEASE HELP ME:confuse d::confuse d: |
09-26-2007, 12:10 | #2 (permalink) |
Insane Poster Join Date: Apr 2006 Location: iraq Age: 43
Member: 264597 Status: Offline Thanks Meter: 2 | you must read full flash from other hand that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware |
09-26-2007, 12:10 | #3 (permalink) |
Member: 264597 Status: Offline Thanks Meter: 2 | you must read full flash from other hand (ZT303) that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware |
09-26-2007, 12:49 | #4 (permalink) | |
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | Quote:
Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash "format ffs" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B015.BIN ver. sw2: U6V10B015 id-page Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 921600 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B19.BIN ver. sw2: U6V10B19 ffs offset/size: 01700000/02900000 id-page Ok nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... write core area 1 of 2... write core area 2 of 2... formatting... Write Done Finished, time used: 296 sec Remove/Install battery now ! SAME PROBLUM BRO PLS HELP ME | |
09-26-2007, 15:58 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: C:\Program Files\
Member: 187451 Status: Offline Thanks Meter: 163 | You guys face this problem coz u dont read its full flash before formatting ffs and writing another firmware.now check with charged bettery.it will take 1 minute to power on.dotn use power supply. |
09-26-2007, 21:54 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @KASAM here is detailed instruction, please, follow it step-by-step: http:///vbb/showthread.php?t=447277 |
11-04-2007, 07:25 | #10 (permalink) |
Freak Poster Join Date: Oct 2003 Location: UK
Member: 42408 Status: Offline Thanks Meter: 6 | cannot find the similiar firmware.... phone:ZTC-ZT303 protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B28.BIN ver. sw2: U6V10B28 what firmware can i write to this phone???? thnaks |
11-04-2007, 11:38 | #11 (permalink) | |
you can find similar firmware in support area: flashfiles\ChineseMiracle\_MT6228 please, before you flash your phone, make "read firmware" procedure before flashing and send backup_flash and backup_system_log files to [email protected] | |
11-04-2007, 12:41 | #12 (permalink) |
Member: 42408 Status: Offline Thanks Meter: 6 | my phone loading 100 % then off.... try all the step but still same problem.... -full back up -format ffs safe and complete -then write U6_PCB04_GPRS_MT6228_S02[1].U6V10B21__En_Fr_Es_Indonesia_Vn_Ru_Th_Cn.B4M.bin - after that phone still loading 100% then off please maybe another solution???? |
12-17-2007, 23:33 | #14 (permalink) | |
Junior Member Join Date: Nov 2003 Age: 43
Member: 44031 Status: Offline Thanks Meter: 0 | Quote:
even i am looking for the same file there are other files in the support area. but they do not end with no. 28 ie: U6V10B28.BIN. can the files currently present in the support area ie: 15, 18, 20, ...... be used insted. | |
12-18-2007, 02:59 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup of your existing firmware and then is safe to try 15, 18, 20. if they will not work properly- you can always return phone to original state by writing back your backup |
New ZTC ZT303 pinout here! | jawad8305 | Chinese Cocktail | 3 | 02-22-2009 06:22 |
New ZTC ZT303 pinout here! | jawad8305 | Infinity-Box | 3 | 02-19-2009 23:34 |
New ZTC ZT303 pinout here! | jawad8305 | SpiderMan | 2 | 02-19-2009 23:32 |
Repair configer fffff then phone off after 5/10 minutes | jabed_net | BB5KING | 12 | 01-07-2009 10:21 |
ZTC ZT303 pinout. | Raklm | Chinese Cocktail | 5 | 11-22-2007 13:52 |
