12-19-2007, 16:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | !!!!!! 6228 Phones 10 - 100 % Fault repair !!!!!! Phone when powered will show 10 to 100 % Bar and phone goes off. These phones dont repair by Formatting FFS, and when you click on Repair Button, the software says "Flash Phone". I have 2 phones here with same fault, Phone 1 = V800_PCB04_GPRS_MT6228_S02.L4A4A06_6_3_1_0T05M0713 _M401.BIN sw2: L4A4A06.6.3.1.0T05M0713_M401 This one gets error when flashing 2 of 2 gets to about 95 % Here is screen shot: Flashed with [V800_PCB04_GPRS_MT6228_S02[1].L4A4A06_6_3_1_0T05M0713_M401__V800_64m_En_Vn_Fr_R u_Th.B4M] COM4 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs identification#1 protocol ver: 04 ver. sw1: V800_PCB04_GPRS_MT6228_S02.L4A4A06_6_3_1_0T05M0713 _M401.BIN ver. sw2: L4A4A06.6.3.1.0T05M0713_M401 ffs offset/size: 02000000/06000000 id-page Ok warning: probably incorrect/unknown source file nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: V800_PCB04_GPRS_MT6228_S02.L4A1G01_6_3_1_1T04M0428 _M401.BIN ver. sw2: L4A1G01.6.3.1.1T04M0428_M401 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... write core area 1 of 2... write core area 2 of 2... error: code: 00000BF4 error: code: FFFFFFFF error: block/offset: 00000E82/00E82000 error: can't write nand core Write Fail Finished, time used: 386 sec Remove/Install battery now ! ===================================== Phone 2 = version: 3.1 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading... detecting structure... converting data... done 0x00010000 bytes identification#1 protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B21.BIN ver. sw2: U6V10B21 ffs offset/size: 01700000/02900000 This one flashed OK 100% using [U6_PCB04_GPRS_MT6228_S02[1].U6V10B21__En_Fr_Es_Indonesia_Vn_Ru_Th_Cn.B4M] but Fault remains, and this seems to be the only flash file closest (or higher) than the one in the phone. How do I repair these phones as i get them often ????? |
China Mobile Phone 100 % working Converter with Tips and tricks | sandy9669 | Chinese Models & Cloned Phones | 30 | 12-18-2009 11:02 |
V3 Repair keypad and led 100 % working | pp_metal | Motorola Hardware Repair | 0 | 07-03-2008 01:39 |
C55 repair 100 % tested | cml | E-Gold Based Phones | 0 | 09-24-2003 15:15 |
i have siemens SL 45 UNLOCKER 100 % WORKING | ultra | x1x to x45/x50 | 23 | 06-11-2001 23:19 |
