Please help infinity Slim Plus not work any cabile please help me hello I have new box slim plus I test 5 mobile no working j100 c261 k750 k800 j100 all not work I have a friend there in old box test all modile all work but my box nothink to work What can I do please helped me i think problem with Entrance cabile with box |
setup ok driver ok com port ok all ok |
can u change the cable and check if it works ? |
yes change 3 cabile same problem not work maybe problem Entrance box |
where r u infinity team |
hello! take motorola rj45 cable and phone. go to your friend's place and check if it will work with his box. if it works with his box, but not work with yours- looks like box internal problem. also, are you sure you set right com port number in program? |
1 Attachment(s) Quote:
all com it's ok no problem plesae ithing problem Entrance cabile how can fix this problem |
hello! what com port number are you using? how did you found it? via device manager? |
it is very hard to advice remoutly, maybe you take your box and cables and ask your skilled friend to help you? |
hello i am not new user for box i have 5 box jaf+ufs+setools+usbsmart +ultpro com port numper 16 ok no problem frinend It gave me box i test with my computer work ok i give my box to my frined test same mobile and not work same problem |
why no help infinity team |
today ı have same problem box RJ45 out dont work cables good, drivers good ı install new OS but same problem ı think FTDİ chip problem... |
if u check every thing cable & com port too that mean have problem into ur box( hardwear) , if u buy new one tthen send back to infinity resaler for reapir it or repalce it , if u buy used from some one then open it & check RJ45 port connecation on main bord resold is then check if still not working then conect 3 wire rx/tx/gnd on box pcb & conectt with mobile & check then u knwo all if u can't finde rx/tx then take a pcb pic & post here botth side of pcb i will tell u all |
all the people with box problem please contact me by email with the following info 1) when was the box purchased 2) resler name 3) how the box stop working our mail is [email protected] |
Brother box works good and excellent but the problem is there is no contact between the mobile and box infinity There are two lighting in the box all work my problem now ithink with rj45 ohw can check work or not work Is there a map of the entrance box how can fix driver instal setup instal comp port select ok |
