Old 10-18-2007, 16:29   #1 (permalink)
Member: 24563
Please help infinity Slim Plus not work any cabile please help me
hello I have new box slim plus I test 5 mobile no working
j100
c261
k750
k800
j100
all not work I have a friend there in old box test all modile all work but my box nothink to work What can I do please helped me i think problem with Entrance cabile with box
Old 10-18-2007, 16:30   #2 (permalink)
Member: 24563
setup ok
driver ok
com port ok
all ok
Old 10-18-2007, 16:55   #3 (permalink)
Member: 128745
Thanks Meter: 16,731
can u change the cable and check if it works ?
Old 10-18-2007, 17:04   #4 (permalink)
Member: 24563
yes change 3 cabile same problem not work
maybe problem Entrance box
Old 10-18-2007, 17:49   #5 (permalink)
Member: 24563
where r u infinity team
Old 10-18-2007, 18:27   #6 (permalink)
Member: 148515
Thanks Meter: 13,329
hello!
take motorola rj45 cable and phone.
go to your friend's place and check if it will work with his box.
if it works with his box, but not work with yours- looks like box internal problem.
also, are you sure you set right com port number in program?
Old 10-18-2007, 19:16   #7 (permalink)
Member: 24563
hello!
yes my brother i take 1 cabile for j100 1 cabile for motorola work 100/100 with my friend box no problem but my box not work
all com it's ok no problem
plesae ithing problem Entrance cabile
how can fix this problem
Old 10-18-2007, 19:23   #8 (permalink)
Member: 148515
hello!
what com port number are you using? how did you found it? via device manager?
Old 10-18-2007, 19:24   #9 (permalink)
Member: 148515
it is very hard to advice remoutly, maybe you take your box and cables and ask your skilled friend to help you?
Old 10-18-2007, 19:43   #10 (permalink)
Member: 24563
hello
i am not new user for box i have 5 box jaf+ufs+setools+usbsmart +ultpro
com port numper 16 ok no problem
frinend It gave me box i test with my computer work ok
i give my box to my frined test same mobile and not work same problem
Old 10-19-2007, 15:25   #11 (permalink)
Member: 24563
why no help infinity team
Old 10-19-2007, 17:33   #12 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 598
today ı have same problem box RJ45 out dont work cables good, drivers good ı install new OS but same problem ı think FTDİ chip problem...
Old 10-19-2007, 17:34   #13 (permalink)
paklink's Avatar
Member: 71321
Sonork: 100.1576579
Thanks Meter: 398
if u check every thing
cable & com port too
that mean have problem into ur box( hardwear) , if u buy new one tthen send back to infinity resaler for reapir it or repalce it , if u buy used from some one then open it & check RJ45 port connecation on main bord resold is then check
if still not working then conect 3 wire rx/tx/gnd on box pcb & conectt with mobile & check then u knwo all
if u can't finde rx/tx then take a pcb pic & post here botth side of pcb i will tell u all
Old 10-19-2007, 18:04   #14 (permalink)
Member: 128745
all the people with box problem please contact me by email with the following info
1) when was the box purchased
2) resler name
3) how the box stop working
our mail is [email protected]
Old 10-19-2007, 21:50   #15 (permalink)
Member: 24563
thankyou for help
Brother box works good and excellent but the problem is there is no contact between the mobile and box infinity There are two lighting in the box all work
my problem now ithink with rj45 ohw can check work or not work
Is there a map of the entrance box how can fix
driver instal
setup instal
comp port select ok
(Pls Help Infinity Support)Infinity Box not working amit.s Infinity-Box 3 10-05-2009 22:54
infinity slim plus rj 45 not working toptech Infinity-Box 4 04-25-2008 08:48
help infinity slim plus original or not saidi321 Infinity-Box 2 01-31-2008 08:38
i have infinity slim box not work ahmertelecom Infinity-Box 10 10-06-2007 12:17
6820 Flip not working - any ideas please ? Seedy Nokia Hardware & Hardware Repair 1 12-18-2004 19:20
Page generated in 0.45767 seconds with 9 queries
