04-18-2016, 15:33 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Nigeria,Lagos
Member: 275290 Status: Offline Thanks Meter: 50 | Please help on this infinix x510, cant flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42006D44E41FA24F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! |
04-18-2016, 21:51 | #4 (permalink) | |
Member: 275290 Status: Offline Thanks Meter: 50 | Quote:
see Operation : Flash [ v1.46 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42006D44E41FA24F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! | |
04-18-2016, 21:53 | #5 (permalink) |
Member: 275290 Status: Offline Thanks Meter: 50 | see result User selected Preloader file : preloader_d5110_infinix.bin Operation : Init Preloader [ v1.46 ] Supported HW by Preloader : FlashID [0] CID : 150100513732534D42 , Name : Q72SMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 150100513858534142 , Name : Q8XSAB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 150100513832534D42 , Name : Q82SMB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 150100523832314D42 , Name : R821MB , Vendor : 15 , [SAMSUNG] FlashID [4] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [5] CID : 150100463832324D42 , Name : F822MB , Vendor : 15 , [SAMSUNG] FlashID [6] CID : 150100513832334D42 , Name : Q823MB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42006D44E41FA24F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! |
04-19-2016, 01:12 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SW can't initialize DRAM memory. ( A tool's warning that DA detects that RAM is un-accessable. ) Reasons - Power latch, or eMMC/eMCP memory problem. Check it first. |
04-20-2016, 14:48 | #9 (permalink) | |
Operation : Check / Read Info [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42006D44E41FA24F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! | |
04-20-2016, 16:33 | #10 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
