11-18-2008, 21:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | PindFinder malfunction I hope you can help me out to solve this issue |
11-19-2008, 00:03 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @tavoonly The error hat you can see is not fatal and we will remove it in next release. I suggest you to read text in software log window more carefully but not concentrate on message box text. As I can see you have tried to detect pinout for 5-pin phone but in many cases if phone has only 5-pin connector there is no RX/TX and connector. You need to open phone and check RX and TX test-points at phone PCB. |
11-19-2008, 00:07 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Quote:
http://forum.gsmhosting.com/vbb/show...40&postcount=4 | |
11-19-2008, 02:01 | #5 (permalink) | |
Member: 586318 Status: Offline Thanks Meter: 112 | Quote:
Thanks for replying, you are right it is not fatal. In fact I was able to set the Tx and Rx pins but It is a little annoying when software cannot detect pins and just freez on and we have to close and open again and again up to three or four times in order to get the detection of the tx and rx pins. Thanks for answering and giving support. BR, | |
spidermane usb pindfinder probleme | nacino | USB Pinfinder | 10 | 03-28-2009 16:44 |
spidermane usb pindfinder probleme | nacino | USB Pinfinder | 5 | 03-15-2009 22:58 |
pindfinder cant detect V666 | ServiceTEL | Infinity-Box | 6 | 08-29-2008 16:08 |
509 keypad malfunction... read on :) | trafix | Various | 9 | 03-02-2002 09:24 |
MC 922 strange malfunction | bulibuba2 | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-05-2001 10:47 |
