11-19-2010, 08:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 609329 Status: Offline Sonork: 100.160.2296 Thanks Meter: 143 | zte 202 dead after unlock,why Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:791D:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05.BIN project-id: ENG-AU-TELSTRA-P109A13V1.0.0B05, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-T202_ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-T202_ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05__ffs_20101119-112444.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ....... required data found flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: area 1 (pass 1) .......... required data found flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: area 1 (pass 2) .............. area 1 patch applied Ok Special operation Done ====> Write ... flash: EC257E25062501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 25 sec Remove/Install battery now |
11-19-2010, 10:30 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | hello bro what module are you ue to unlcok this fone i think is QC module don't see sp unlock in soft ???????????????? are you use infinity box? |
11-25-2010, 10:02 | #3 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 54
Member: 320105 Status: Offline Thanks Meter: 18 | zte 202 telstra dead after unlock === [11/25/2010 1:17:05 PM] ==== COM10 [VCP0] selected module v3.64 Device: ZTE-T202 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:68EF:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05.BIN project-id: ENG-AU-TELSTRA-P109A13V1.0.0B05, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-T202_ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-T202_ZTENJ23D_08B_PCB01_GSM_MT6223_S00.ENG-AU-TELSTRA-P109A13V1_0_0B05__ffs_20101125-131934.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ....... required data found flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: area 1 (pass 1) .......... required data found flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: area 1 (pass 2) .............. area 1 patch applied Ok Special operation Done ====> Write ... flash: EC257E25062501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 45 sec Remove/Install battery now ! after flash phone with flash file from support power on normaly but not unlocked |
11-30-2010, 09:06 | #6 (permalink) |
Member: 320105 Status: Offline Thanks Meter: 18 | phone successfully unlocked after write backup eeprom and smart fast sp ulock method COM10 [VCP0] selected module v3.64 Action: "sp-unlock" unlock method: smart fast Model: ZTE-T202 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:68EF:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: ENG-AU-TELSTRA-P109A13V1.0.0B05 Version: ZTENJ23D_08B_HW 80 byte(s) read imei: 35160504010007 connection Ok 116 byte(s) read reading data... reading data #2... building new data... writing data... 115 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to williamvirk For This Useful Post: |
02-17-2011, 11:11 | #7 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 578858 Status: Offline Thanks Meter: 26 | 10000000000% Quote:
thanks dear you are welcome | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
