Old 03-03-2016, 15:28   #1 (permalink)
unlocker_786's Avatar
Member: 711273
Thanks Meter: 81
please help me about cm2 i just activate today but face problem
hi
i just activated cm2 with my infinity box successfully for spd7731 cpu huawei y366-u02 but dis phone can't connect with program software freeze in all function can't flash can't write imei also read nv write nv read info but just connect and freeze so i must need to remove usb i try with different ver also driver is all correct but dis phone does not connect with cm2 problem is phone has only emergency network so i need to flash it or write other nv so phone can access network don't ask me about driver many spd phone i m flashing here with success and i can't select model from software always hide model select tab only access cpu select tab
Card found: S/N : 0EE5F124 , v0130
Chinese Miracle II [SPD module] v 1.15
Operation : Scan APP's [ v1.15 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 8 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Loader start failed! Wrong Model selection!
Boot failed!
Reconnect Power/Cable!
Old 03-03-2016, 15:41   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Need to select correct model and sldr to work with this phone.
-Go to Setting tab
-In cpu select last option- SP SC77xx [Model Select]
-Go to Flash tab, click on Pac button-
-Navigate to C:\InfinityBox\CM2SPD\Models folder and select Huawei_Y336_Y3C.sldr
Now you can do required operation.
Remember it's secured phone so flashing is not recommended. For flashing download factory file from support area.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.14193 seconds with 8 queries
