04-13-2016, 17:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Ghana takoradi
Member: 793188 Status: Offline Thanks Meter: 55 | please help me here!!!!!!!!!Flash file Needed Operation : Read Flash [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930101E9DAF568077 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930101E9DAF568077 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 402E28FBB253686EA75A523AF23AEC52 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : C130 ProdName : C130 ProdModel : C130 Device : C130 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : NIPDA-JDQ39.I9190XXUAMF7 |
04-13-2016, 18:12 | #2 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Google request on Quote:
So, just try use search. We made all such features, as read info and extended info exactly for that. | ||
04-13-2016, 19:46 | #4 (permalink) |
Member: 793188 Status: Offline Thanks Meter: 55 | Chinese Miracle II [MTK module] v 1.45 Start at : [4/13/2016 / 7:44:44 PM] Operation : Check / Read Info [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930101E9DAF568077 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930101E9DAF568077 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 402E28FBB253686EA75A523AF23AEC52 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : C130 ProdName : C130 ProdModel : C130 Device : C130 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : NIPDA-JDQ39.I9190XXUAMF7 EXTRA : LCD [0] : hx8369_rgb_6572_wvgalnl LCD Res : 800x480 TOUCH [0] : bf6751 TOUCH [1] : GSLX680 CAM [0] : sp0a19_yuv CAM [1] : main_sp0a19_yuv CAM [2] : siv121du_yuv CAM [3] : siv121du_yuv gc0328_yuv sp2518_yuv MODEM : GPRS_NOEDGE_VCX0_GPS LOCALE : en_US ru_RU zh_CN zh_TW ar_EG in_ID ms_MY de_DE es_ES it_IT pt_BR vi_VN tr_TR fa_IR hi_IN th_TH fr_FR hdpi -sw600dp -sw720dp pt_PT nl_NL my_MM Done! |
04-14-2016, 12:27 | #5 (permalink) |
Member: 793188 Status: Offline Thanks Meter: 55 | please help me get this flashfile... Chinese Miracle II [MTK module] v 1.45 Start at : [4/13/2016 / 7:44:44 PM] Operation : Check / Read Info [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930101E9DAF568077 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930101E9DAF568077 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 402E28FBB253686EA75A523AF23AEC52 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : C130 ProdName : C130 ProdModel : C130 Device : C130 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : NIPDA-JDQ39.I9190XXUAMF7 EXTRA : LCD [0] : hx8369_rgb_6572_wvgalnl LCD Res : 800x480 TOUCH [0] : bf6751 TOUCH [1] : GSLX680 CAM [0] : sp0a19_yuv CAM [1] : main_sp0a19_yuv CAM [2] : siv121du_yuv CAM [3] : siv121du_yuv gc0328_yuv sp2518_yuv MODEM : GPRS_NOEDGE_VCX0_GPS LOCALE : en_US ru_RU zh_CN zh_TW ar_EG in_ID ms_MY de_DE es_ES it_IT pt_BR vi_VN tr_TR fa_IR hi_IN th_TH fr_FR hdpi -sw600dp -sw720dp pt_PT nl_NL my_MM Done! |
