please help me infinity team its very urgent. hi infinity team , i have a china phone for resetting the lock code, i ahve tried evry thing but the lock code was not resetted. also i does'nt have the backup of full flash. on flashing with this flash file ZT588_E553_Y8ARTF_E553_GPRS_MT6226_S01[1].01_1_16m_En_Fr_Ru_Ar_Th.B0M.bin from the support site the phone was on but no display was coming. please help me to supply the same version of flash file from the phone. the flash file version of the phone is:- backup_eeprom[M858_PCB01_GPRS_MT6226_S01.M858_6226B_13.BIN]_20071217-213503.B0E.bin i have also attached the picture of the phone model. http://forum.gsmhosting.com/vbb/showthread.php?t=481663 unfortunately a second same china phone came to me . i read the backup of firmware and eeprom and flashed the pprevious phone with these flash files . everything was perfectly written but the phone did'nt power up.the phone is still dead. backup_flash[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]_20080119-163920.B0M.bin backup_eeprom[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]_20080119-190904.B0E.bin |
You must flash phone with this firmware: M858_PCB01_GPRS_MT6226_S01.M858_6226B_13 Do you have full flash backup from this phone ? |
no i does not have backup yhe previous phone .now i have powered on the phone from spiderman cracked software with the option (unprotect mtk2) but the phone was still in the previous problem :enter phone code . i have also done repair security area with infinity but the problem is same COM2 [VCP19] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C968:A56F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858dfxsp_6226b_11 Version: M858_01 detecting structure #2... repeat detection item#0 done 44 byte(s) read imei: 35761501007408 connection Ok detecting structure #1... repeat detection item#0 done 145 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: FF005566/FF005566 locked to: FFF-FF NS code: FFFFFFFFFFC1C1C1/FFFFFFFFFF1C1C1C NP of SP: FFF-FF NP of CP: FFF-FF Phone code: FFFFFFFFFF000000 Finished, time used: 20 sec Remove/Install battery now ! |
Make "user code" unlock with "smart safe" method. Post here results and log. Also send me firmware that you have used for flashing to: [email protected] |
COM2 [VCP19] selected Action: user code unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C968:A56F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858dfxsp_6226b_11 Version: M858_01 detecting structure #2... repeat detection item#0 done 44 byte(s) read warning: wrong packet cs imei: 35887900002112 connection Ok detecting structure #1... repeat detection item#0 done 145 byte(s) read reading data... building new data... writing data... user code set to: 0000 Finished, time used: 15 sec Remove/Install battery now ! |
And what is the final results ? |
Network lock: On same problem it is asking for phone code now also |
Hello, Try to make "format ffs" now. First "safe", then "complete" (if "safe" not helps). |
all try this sir my problem is not solved any help me |
Hello, 1. please, check phone imei. Write correct imei. (some phones show something like "locked" when imei is incorrect) 2. make "complete format". make "read codes", post log here to check 3. flash phone with another firmware. |
my problem no solved sir help me b.r yuvi |
hello Yuvi! please do not ignore step 2 in given advices |
hear a fust log COM3 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C968:A56F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6C644927.[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN_D2B3956E].rpl identification#1 detection finished device-id: 6C644927 identification#1 protocol ver: 04 ver. sw1: M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN ver. sw2: M858dfxsp_6226b_11, 916A4C2D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF flash: 98004900000002:2AEA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:2AEA0000000000 Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _6C644927_M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXS P_6226B_11.BIN_D2B3956E_20080207-203723.B0X.bin Finished, time used: 42 sec Remove/Install battery now ! hear is a 2nd log COM3 [Serial2] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C968:A56F Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: M858dfxsp_6226b_11 Version: M858_01 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 connection Ok detecting structure #1... 0 done 145 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: FF005566/FF005566 locked to: FFF-FF NS code: FFFFFFFFFFC1C1C1/FFFFFFFFFF1C1C1C NP of SP: FFF-FF NP of CP: FFF-FF Phone code: FFFFFFFFFF000000 Finished, time used: 33 sec Remove/Install battery now ! but same problem |
hello! thank you for log file, we need small time to response |
@Yuvi How about to make step-1 from my previous advice: http://forum.gsmhosting.com/vbb/show...1&postcount=10 Check phone after this operation. |
