Old 01-19-2008, 15:03   #1 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
please help me infinity team its very urgent.
hi infinity team ,
i have a china phone for resetting the lock code, i ahve tried evry thing but the lock code was not resetted. also i does'nt have the backup of full flash.
on flashing with this flash file
ZT588_E553_Y8ARTF_E553_GPRS_MT6226_S01[1].01_1_16m_En_Fr_Ru_Ar_Th.B0M.bin from the support site the phone was on but no display was coming. please help me to supply the same version of flash file from the phone.
the flash file version of the phone is:-
backup_eeprom[M858_PCB01_GPRS_MT6226_S01.M858_6226B_13.BIN]_20071217-213503.B0E.bin
i have also attached the picture of the phone model.
http://forum.gsmhosting.com/vbb/showthread.php?t=481663
unfortunately a second same china phone came to me . i read the backup of firmware and eeprom and flashed the pprevious phone with these flash files . everything was perfectly written but the phone did'nt power up.the phone is still dead.
backup_flash[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]_20080119-163920.B0M.bin
backup_eeprom[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN]_20080119-190904.B0E.bin
Old 01-19-2008, 15:43   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
You must flash phone with this firmware: M858_PCB01_GPRS_MT6226_S01.M858_6226B_13
Do you have full flash backup from this phone ?
Old 01-19-2008, 16:18   #3 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
no i does not have backup yhe previous phone .now i have powered on the phone from spiderman cracked software with the option (unprotect mtk2) but the phone was still in the previous problem :enter phone code . i have also done repair security area with infinity but the problem is same
COM2 [VCP19] selected
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:C968:A56F
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: M858dfxsp_6226b_11
Version: M858_01
detecting structure #2...
repeat detection item#0
done
44 byte(s) read
imei: 35761501007408
connection Ok
detecting structure #1...
done
145 byte(s) read
Phone lock: Off
Network lock: On
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
NP code: FF005566/FF005566
locked to: FFF-FF
NS code: FFFFFFFFFFC1C1C1/FFFFFFFFFF1C1C1C
NP of SP: FFF-FF
NP of CP: FFF-FF
Phone code: FFFFFFFFFF000000
Finished, time used: 20 sec
Remove/Install battery now !
Old 01-19-2008, 17:25   #4 (permalink)
Member: 130995
Make "user code" unlock with "smart safe" method.
Post here results and log.
Also send me firmware that you have used for flashing to: [email protected]
Old 01-19-2008, 17:33   #5 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
Action: user code
unlock method: smart fast
19200
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: M858_01
done
44 byte(s) read
warning: wrong packet cs
imei: 35887900002112
connection Ok
done
145 byte(s) read
reading data...
building new data...
writing data...
user code set to: 0000
Finished, time used: 15 sec
Old 01-19-2008, 18:38   #6 (permalink)
Member: 130995
And what is the final results ?
Old 01-20-2008, 15:31   #7 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
Network lock: On
same problem it is asking for phone code now also
Old 01-20-2008, 22:49   #8 (permalink)
Member: 130995
Hello,
Try to make "format ffs" now. First "safe", then "complete" (if "safe" not helps).
Old 01-21-2008, 16:35   #9 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
all try this sir
my problem is not solved
any help me
Old 01-21-2008, 23:46   #10 (permalink)
Member: 130995
Hello,
1. please, check phone imei. Write correct imei. (some phones show something like "locked" when imei is incorrect)
2. make "complete format". make "read codes", post log here to check
3. flash phone with another firmware.
Old 02-06-2008, 12:50   #11 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
my problem no solved sir
help me
b.r
yuvi
Old 02-06-2008, 20:22   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
hello Yuvi!
please do not ignore step 2 in given advices
Old 02-07-2008, 16:13   #13 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
hear a fust log
COM3 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
CPU: MT6226
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6C644927.[M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN_D2B3956E].rpl
identification#1 detection finished
device-id: 6C644927
identification#1 protocol ver: 04
ver. sw1: M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXSP_6226B_11 .BIN
ver. sw2: M858dfxsp_6226b_11, 916A4C2D
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _6C644927_M858DFXSP_PCB01_GPRS_MT6226_S01.M858DFXS P_6226B_11.BIN_D2B3956E_20080207-203723.B0X.bin
Finished, time used: 42 sec
hear is a 2nd log
Action: read codes
19200
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: M858_01
0
done
44 byte(s) read
imei: 13579024681122
connection Ok
detecting structure #1... 0
done
145 byte(s) read
Phone lock: Off
Network lock: On
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
locked to: FFF-FF
NP of SP: FFF-FF
NP of CP: FFF-FF
Finished, time used: 33 sec
but same problem
Old 02-07-2008, 23:58   #14 (permalink)
Member: 148515
hello!
thank you for log file, we need small time to response
Old 02-08-2008, 09:03   #15 (permalink)
Member: 130995
@Yuvi
How about to make step-1 from my previous advice: http://forum.gsmhosting.com/vbb/show...1&postcount=10
Check phone after this operation.
lg u400 ,,uk,, unlock plz help me any body its very urgent mobiletuch LG Hardware Repair 0 01-31-2010 13:00
Pls Help me Infinity Team its very urjent .::Raj::. Infinity-Box 2 11-07-2009 02:13
Please Help Me Infinity Team For Motorola W210 Tajammul Infinity-Box 1 01-14-2009 17:28
Need flash file please help me infinity team eswar7983 Infinity-Box 9 09-22-2008 23:10
i have probel with flash c118 please help me infinity team gsm4libya Infinity-Box 2 05-11-2006 12:03
Page generated in 0.27993 seconds with 10 queries
