02-17-2008, 11:35 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 700952 Status: Offline Thanks Meter: 9 | please help me to know ZTC KMS 168 PINOUT dual sim cards mobile phone kms 168 with gprs bluetooth camera in large quantity please help me to know ZTC 168 PINOUT IN BACK OF THE MOBILE ZTC 168 |
02-17-2008, 13:30 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-18-2008, 10:08 | #3 (permalink) |
Member: 700952 Status: Offline Thanks Meter: 9 | boot initialization step-2 thank you very much PINOUT read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: TELSDA26_05C_HW Software version: MAUI.05C.W06.16.MP.V Software date: 2005.04.12 Barcode: MT012345678901234567 10 imei: 354565002103012 Finished, time used: 48 sec Power off phone now ! ....................................... put i still need you help Trying to format get an error Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: boot initialization step-2 failed: 00 19200 error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 207 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! ................................. Action: reset enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: boot initialization step-2 failed: 00 error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 8 sec Remove/Install battery now ! Last edited by CaffeCalls; 02-18-2008 at 10:14. Reason: TO LINK |
The Following User Says Thank You to CaffeCalls For This Useful Post: |
03-16-2008, 16:56 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 5 sec Remove/Install battery now ! ihave same probleme with to methode |
03-16-2008, 21:21 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello! disable "boot autodetection autoselect" and try different boot step from drop down menu "2, 10, 1000" with each time you must mke try and please do not forget to HOLD power button pressed untill program asks to release it |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
i have to Q please help me to know the answer!!! | SOFT3000 | MT-BOX | 1 | 01-28-2009 00:45 |
help me to know the model of this chinese phone | tsarkh | Infinity-Box | 4 | 09-28-2007 15:22 |
