Old 01-08-2011, 14:21   #1 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
Please help me for lava kkt25 input password
hi sir i have LAVA KKT25 phone which asking input password while factory reset, i done USER/LOCKCODE but not working
COM47 [VCP6] selected
module  v3.24
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6228-6239 NAND
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:E703:0009
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: LBBQK01.8.5.1.4T22G0114_M571
Version: LBBM571
detecting structure #2...
 1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35868800000015
connection Ok
detecting structure #1...
 0 2 3 4 7 12 13 15 16 18 19 20 23 28 29 31error: detection failed (16 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
also i tried to FFS COMPLETE MODE but not working ,means format done successfully but password not reseted
module  v3.24
Device: Autodetect 6205-6239 NOR
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====>  Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.24, database date: 01.10.2010):
LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571.BIN
project-id: LBBQK01.8.5.1.4T22G0114_M571, 00000000
code offset: 00000000
ffs offset/size [01]: 00D40000/002C0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00D40000
standard ffs/eeprom offset confirmed: 00D40000
detecting ffs/eeprom size...
ffs/eeprom size: 002C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00D40000-00FFFFFF
firmware area: 00000000-00D3FFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571__ffs_20110108-184510.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 45 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
so will you please guide me for this also i readed full flash if you need
Old 01-08-2011, 22:19   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i am sure that this can be repaired by flashing, but unfortunately, we dont have such flash file
Old 01-10-2011, 06:52   #3 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
is it not similar flash file of ur phone?
http://forum.gsmhosting.com/vbb/f425...-here-1168956/
Old 01-10-2011, 12:52   #4 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
BR, your link is not working will you please give me any other link?
Old 01-10-2011, 17:18   #5 (permalink)
Member: 432679
Thanks Meter: 118
I AM ALSO LOOKING FOR FLASHFILE...i allready send file to infinity team but its not their in support area
regards!
Old 01-10-2011, 19:30   #6 (permalink)
Member: 148515
regards!
hello!
this file is downloaded and pre-processed. soon it will appear on support site
Old 01-11-2011, 06:30   #7 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
thank you sir i found it at support
Old 01-11-2011, 07:38   #8 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
hi sir
i flashed both the files from support area but my password not resetted sir please guide me .
COM7 [Serial2] selected
module  v3.24
Action: write flash
"smart write" active
write: Firmware
LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_3T20G0108_M571_2010-01-09__LAVA-KKT25_16m_En_Hi.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
New firmware found (v.3.24, database date: 23.12.2010):
LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_3T20G0108_M571.BIN
rom info ver: 05
sw version: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_3T20G0108_M571.BIN
project-id: LBBQK01.8.5.1.3T20G0108_M571, 00000000
TCL-ID is absent
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00D80000
Detected ffs/eeprom address is non-standard: 00D80000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00D80000
ffs/eeprom size: 00280000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00D80000-00FFFFFF
firmware area: 00000000-00D7FFFF
reading: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_3T20G0108_M571__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_3T20G0108_M571__ffs_20110111-113215.B0E.bin
====>  Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 11 min 56 sec
module  v3.24
Action: write flash
write: Firmware
LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571_2010-01-14__LAVA-KKT25_16m_En_Hi.B0M.bin
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571__ffs_20110111-111141.B0E.bin
====>  Write ...
done
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 2 min 24 sec
Old 01-11-2011, 22:02   #9 (permalink)
Member: 148515
hello!
maybe this phones has second CPU 6223? can you check this?
Old 01-12-2011, 06:35   #10 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
hello!
oh no , sir customer not ready to wait more so he took back his phone
Old 01-19-2011, 17:25   #11 (permalink)
Member: 432679
Thanks Meter: 118
finally successfull unlocked in avator box
regards!
Page generated in 0.22777 seconds with 10 queries
