04-11-2009, 15:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Please Help Me with LG C2600 Seems as if Flash Is Damaged. There r two Flashes(1 BGA and another seems to be SAMSUNG Flash(128MB)), can somebody guide me Which one is Faulty???? Here goes the detailed INFO log. Code: module v2.69 Device: LG-C2600 Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: FFFFFFFFFFFFFF:29EA0000000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:44F7D400000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #02 in region #00... flash: FFFFFFFFFFFFFF:41914B00000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #03 in region #00... flash: FFFFFFFFFFFFFF:02479000000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #04 in region #00... flash: FFFFFFFFFFFFFF:01541900000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: Amd AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #05 in region #00... flash: FFFFFFFFFFFFFF:FFF8C000000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #06 in region #00... flash: FFFFFFFFFFFFFF:A6FA3E00000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #07 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #08 in region #00... flash: FFFFFFFFFFFFFF:09428200000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #09 in region #00... flash: FFFFFFFFFFFFFF:FE000000000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0A in region #00... flash: FFFFFFFFFFFFFF:04F0A600000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: Fujitsu AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0B in region #00... flash: FFFFFFFFFFFFFF:5CD01400000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0C in region #00... flash: FFFFFFFFFFFFFF:C218D200000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0D in region #00... flash: FFFFFFFFFFFFFF:29310900000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0E in region #00... flash: FFFFFFFFFFFFFF:B8E00100000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0F in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 warning: detected/calculated [01000000/00040000] chip size mismatch, chip detection error flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 27 sec Remove/Install battery now ! |
04-11-2009, 21:11 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, NOR flash chip (BGA) is empty. It may be damaged or may be just erased, so at first try to flash phone with firmware from support area and see results. |
04-17-2009, 08:13 | #3 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | Thanks a lot sir for ur reply. But Flashing and erasing aren't working. Code: Device: LG-C2600 Checking data, wait... advanced flash detection enabled Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: FFFFFFFFFFFFFF:29EA0000000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:44F7D400000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #02 in region #00... flash: FFFFFFFFFFFFFF:41914B00000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #03 in region #00... flash: FFFFFFFFFFFFFF:02479000000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #04 in region #00... flash: FFFFFFFFFFFFFF:01541900000000 flash: Amd AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #05 in region #00... flash: FFFFFFFFFFFFFF:FFF8C000000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #06 in region #00... flash: FFFFFFFFFFFFFF:A6FA3E00000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #07 in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #08 in region #00... flash: FFFFFFFFFFFFFF:09428200000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #09 in region #00... flash: FFFFFFFFFFFFFF:FE000000000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0A in region #00... flash: FFFFFFFFFFFFFF:04F0A600000000 flash: Fujitsu AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0B in region #00... flash: FFFFFFFFFFFFFF:5CD01400000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0C in region #00... flash: FFFFFFFFFFFFFF:C218D200000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0D in region #00... flash: FFFFFFFFFFFFFF:29310900000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0E in region #00... flash: FFFFFFFFFFFFFF:B8E00100000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb detecting chip #0F in region #00... flash: FFFFFFFFFFFFFF:FFFFFF00000000 flash: AMD/Fujitsu std [U 0004x010000 003Ex040000 0004x010000] 0Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: FFFFFFFFFFFFFF:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: FFFFFFFFFFFFFF:29EA0000000000 Erase: chip 1 of 16 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 error: error# 00000029 error: flash erase error: 00000000 flash: FFFFFFFFFFFFFF:44F7D400000000 Erase: chip 2 of 16 flash: FFFFFFFFFFFFFF:41914B00000000 Erase: chip 3 of 16 flash: FFFFFFFFFFFFFF:02479000000000 Erase: chip 4 of 16 flash: FFFFFFFFFFFFFF:01541900000000 Erase: chip 5 of 16 flash: FFFFFFFFFFFFFF:FFF8C000000000 Erase: chip 6 of 16 flash: FFFFFFFFFFFFFF:A6FA3E00000000 Erase: chip 7 of 16 flash: FFFFFFFFFFFFFF:FFFFFF00000000 Erase: chip 8 of 16 flash: FFFFFFFFFFFFFF:09428200000000 Erase: chip 9 of 16 flash: FFFFFFFFFFFFFF:FE000000000000 Erase: chip 10 of 16 flash: FFFFFFFFFFFFFF:04F0A600000000 Erase: chip 11 of 16 flash: FFFFFFFFFFFFFF:5CD01400000000 Erase: chip 12 of 16 flash: FFFFFFFFFFFFFF:C218D200000000 Erase: chip 13 of 16 flash: FFFFFFFFFFFFFF:29310900000000 Erase: chip 14 of 16 flash: FFFFFFFFFFFFFF:B8E00100000000 Erase: chip 15 of 16 flash: FFFFFFFFFFFFFF:FFFFFF00000000 Erase: chip 16 of 16 Finalization Fail Finished, time used: 218 sec Remove/Install battery now ! Thanks |
Please, Please, Please Help Me With Codes - I Am Going Insane! | janeyjewel | CAR Electronics | 1 | 07-23-2007 00:58 |
Please help me with lg 8290 start problem... | uti79 | NSPRO | 0 | 05-15-2006 17:02 |
please help me unlock lg 4011 with furious box2 | bengrippin | FuriouS II | 5 | 08-27-2005 22:02 |
please please please help me with my C350 | EssO | Motorola P2k | 12 | 02-27-2004 13:52 |
Can somebody help me with LG W7020 pinout,please ?! | seyken | LG | 0 | 05-05-2003 18:16 |
