10-13-2009, 23:39 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | i juste unlocked one ot-v570 u can use this pinout if dont have the cable good luck bro COM108 [VCP0] selected module v2.84 Device: Alcatel-V570X, V570A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware V570X-2DALAP1-2-746_XD74BM01_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2008-10-31_En_Fr_Tr_Ar_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:8003:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.AB874 B80.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_A8B79B37].rpl rom info detection finished device-id: AB874B80 rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, C8644857 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device sec info... detection phase #1... detect device sec info finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35402902022781 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V570X,V570A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_AB874B80_A8B79B37_20 091013-225920.B0X.bin Area: Firmware flash: 01227E22442200:18E59F00000000 Write: Firmware detect device sec info... detection phase #1... detect device sec info finished security area (sec info, part #2) calculation... customization: CD74BM01 done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V570X,V570A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_AB874B80_A8B79B37_20 091013-232325.B0X.bin Finished, time used: 1486 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [13/10/2009 23:24:12] ==== COM108 [VCP0] selected module v2.84 Action: reset settings Model: Alcatel-V570X, V570A Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:8003:A002 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.28.SP1.V34 Version: JRD25_06B_HW 44 byte(s) read imei: 35402902022781 connection Ok building list... done items to clear: 310 warning: wrong packet cs warning: wrong packet cs items cleared: 310 of 310 building list... done items remains: 0 Finished, time used: 38 sec Remove/Install battery now ! |
The Following User Says Thank You to yahia ali For This Useful Post: |
please help with pinout FOR 8800e-1 2sim | samih127 | Infinity-Box | 2 | 07-14-2009 01:49 |
please help with pinOUT FOR N95 8GB RM 145 | ServiceTEL | Infinity-Box | 12 | 06-06-2009 04:47 |
please help with pinout FOR 8800e-1 Art | Denozaur | Infinity-Box | 2 | 05-12-2009 19:14 |
Please help with pinout of 639. | korter | Philips | 1 | 03-13-2009 16:04 |
Please help with my OT 501 | iquo | Alcatel & TCL Old Models | 3 | 06-10-2003 12:54 |
