Old 01-27-2009, 15:07   #1 (permalink)
Member: 516358
Thanks Meter: 12
please help sciphone i68 dead after enginner mode
hello
I have a computer problem with a clone of iphone (sciphone + i68) after putting in so engineer and restore some settings the phone is dead: S I tried to restore infinity but always pulls me connection error (I used the pinout that is directly to board but not recognized as fix this?
I have more of these 2 teams but all say they quald band signal but none I have tried to restore via usb and rj but always gives me the same mistake I would like to know I can put to work thanks for your attention!
forgiveness for my bad English
Old 01-27-2009, 16:41   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Post here operation log text so we will be able to see what is wrong.
Old 01-27-2009, 21:21   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
does pinout on PCB is mared ? as tx/rx ?
Old 01-29-2009, 01:30   #4 (permalink)
Member: 516358
Thanks Meter: 12
hello
thank you for responding so quickly very good team
and hopefully can fix it!
around here the log and screen
I have a backup EPROM and fullflash I made another sciphone i68 , where you can upload it for me to make the flash
thanks for your attention and I apologize for my bad English
==== log: [28/01/2009 06:12:48 p.m.] ====
COM8 [VCP0] selected
module v2.75
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "repair imei"
imei write method: mode-3
imei write channel: imei #1 for dual sim/mono CPU
new imei: 358967002774527
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:BC03:0007
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 89890100040089:89890100000000
flash: Intel ST [def 0080x040000] 32Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Archivos de programa\InfinityBox\ChineseMiracle\operation.log
2. C:\Archivos de programa\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx. bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 02000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 01C00000
checking area [00000000]: 00000000-01FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 01C00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00400000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01C00000-01FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\eeprom_2009012 8-182253.B0E.bin
Backup required data Done
Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "repair imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "repair imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 610 sec
Remove/Install battery now !
Old 01-29-2009, 11:40   #5 (permalink)
Member: 130995
Hello,
It looks like flash chip of your phone is erased. You must flash phone with good firmware.
If you have good flash backup from the same phone you can send backup to [email protected]
Also you can try to use the next files from support:
\flashfiles\ChineseMiracle\_MT6225\TELSDA25_07B_PC B01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_0__Scipho ne-i68_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt. B0M.bin
\flashfiles\ChineseMiracle\_MT6225\TOP25_06B_PCB01 _GPRS_MT6225_S00.MAUI_06B_W07_28_MP_V8__SCiPhone_i 68_32m_En_Ru_Nl_Fr_Es_It_De_Th_Vn_Cn_Tr_Pt_Cn_Ar.B 0M.bin
\flashfiles\ChineseMiracle\_MT6225\32m\TELSDA25_07 B_PCB01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_3__SC iPhone-i68+_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt .B0M.bin
Old 01-29-2009, 19:34   #6 (permalink)
Member: 516358
Thanks Meter: 12
Thank you very much infinity team
sciphone lives of the new medium with excellent array of the following flash \flashfiles\ChineseMiracle\_MT6225\32m\TELSDA25_07 B_PCB01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_3__SC iPhone-i68+_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt .B0M.bin
as could fix the problem and not signal invalid sim
very very grateful!
Old 01-29-2009, 20:38   #7 (permalink)
Member: 958386
hello
can you explain how did you flashed your phone?
what cable?
Sorry for my english translation
Old 01-30-2009, 01:53   #8 (permalink)
Member: 516358
Thanks Meter: 12
hello
what cable?
Hi
The Following 2 Users Say Thank You to kiubo For This Useful Post:
Old 01-30-2009, 22:08   #9 (permalink)
Member: 958386
thank you.
but his need to connect a usb cable?
com?
sorry
Old 01-30-2009, 23:23   #10 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
Originally Posted by bloodturf View Post
thank you.
com?
sorry
this is alternative pinout...
use RJ45
B.R
Old 01-30-2009, 23:27   #11 (permalink)
Member: 130995
thank you.
com?
sorry
Hello,
You must use Rx/Tx/Gnd cable
Old 01-31-2009, 09:38   #12 (permalink)
Member: 958386
thank you.
could you give me a link to download the firmware upgrade for my i68 in I68 +.
Old 01-31-2009, 13:43   #13 (permalink)
Member: 148515
thank you.
hello!
correct flash file name can be given only after you assemble Com port cable and make "read detailed information".
also: what problem is with your phone? maybe we can advice repair method which will not require flashing
Old 01-31-2009, 15:21   #14 (permalink)
Member: 958386
sim speed then black screen.
thanks for help
Old 01-31-2009, 20:34   #15 (permalink)
Member: 148515
hello!
i would advice to start from Format FFS (safe)
if will not help - then continue with Format FFS (complete)
!before make backup for emergency case!
CRUISER TEAM PLEASE HELP ME K310i dead after unloking .::ricky rayya::. Phone Unlocking Codes & Maps 5 04-20-2007 08:40
Zulea,please Help!! my 802sh dead after flashing superwing1248 SonyEricsson (USB-Smart) 2 10-18-2005 12:57
Please help rescue 6680 dead after trying to connect Keke Nokia Base Band 5 ( BB-5 ) 0 10-10-2005 10:32
Please HELP!!!! A-300 dead after flashing RomaK VLSI, Conexant, Skyworks and Old Models 1 11-15-2002 20:09
Page generated in 0.29300 seconds with 10 queries
