10-30-2016, 15:38 | #1 (permalink) |
Major Poster Join Date: Oct 2016 Location: Bangladesh Age: 34
Member: 2633625 Status: Offline Sonork: 100.1675507 Thanks Meter: 17 | Please Help symphony w140 not flashing boot error? 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 204A0190594E49588CA116488170663A Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED 0x00 Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
04-24-2017, 09:43 | #2 (permalink) |
Junior Member Join Date: Jan 2015 Location: Bagladesh
Member: 2325926 Status: Offline Thanks Meter: 10 | Operation : Fix DL Errors [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 67 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 204A0190594E495886A11648EF70AE5F Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x00000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED 0x00 Boot Error! I also have same problem |
