Old 08-15-2010, 09:30   #1 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
china L800 both sim invalid imei
china L800 show invalid imei both
format and then write imei but failed in imer written
when format giving this error
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_ANX_F1 4_VT_V01_091112__ffs_20100815-130822.B0E
Old 08-15-2010, 11:20   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
use IMEI writing method 1 or 2
post here log
Old 08-15-2010, 11:22   #3 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
@InfinityHelp
I had same problem... But I fixed using method 2... Try that might work out.
BR,
ERIC
Old 02-09-2011, 07:08   #4 (permalink)
Member: 200761
Thanks Meter: 10
China L800 both sim invalid imei
COM6 [VCP1] selected
module v3.26
Action: "repair imei"
imei write method: mode-2
imei write channel: imei #2 for dual sim/mono CPU
new imei: 357838030454955
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7E03:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: R206AF_ANX_F14_SDT_V03_091228
Version: RONCENT25_GEMINI_08B_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35783803045395
connection Ok
80 byte(s) read
verification...
verification done: 35783803045495
Finished, time used: 11 sec
Remove/Install battery now !
Working perfect
The Following User Says Thank You to shahabu3 For This Useful Post:
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.14785 seconds with 9 queries
