Please Help ******* Test Points of RJ45******* Hi guys, I have a confusion... If i know RX TX on board & If i solder test-points to PCB with RJ45 Cable... still do i have to open pinfinder application to check for rx tx pinouts or directly i can work with chinese miracle application... Thanks in Advance... |
no need for pinfinder if connected rx tx gnd then no need for pinfinder use box rj45 port and you and connected give phone power from power supply |
1= RX 2=TX 3=GND With using of Battery. If u do not want to use battery then Use 4th pin of Plus supply of ur rj45 cable and connect it to +Vbatt on ur fone pcb. and do the power on of pinfinder .Plus voltage are comming out from pin # 1 of rj45 cable of infinity . |
hello! yes, this is correct: no need pinfinder when you are using test points. just take Rj45 cable and solder 3 wirs to PCB. pin 2&3 to tx&rx pins and pin8 to phone's GND |
thank you all... Thanks a lot guys.......... |
