Old 02-05-2011, 22:52   #1 (permalink)
Member: 1496671
Thanks Meter: 88
Please Help ******* Test Points of RJ45*******
Hi guys,
I have a confusion... If i know RX TX on board & If i solder test-points to PCB with RJ45 Cable... still do i have to open pinfinder application to check for rx tx pinouts or directly i can work with chinese miracle application...
Thanks in Advance...
Old 02-06-2011, 02:12   #2 (permalink)
Member: 1239414
Thanks Meter: 2
Originally Posted by King_ View Post
Hi guys,
Could you please upload the picture of your RX TX Point of PCB? You still need to check pinouts, I believe.
Old 02-06-2011, 04:00   #3 (permalink)
sanjeewa57's Avatar
Member: 170619
Thanks Meter: 13
Hi guys,
if you know rx tx in phone connect box RJ -45 connecter PIN 2 (TX) to phone RX , PIN 3 (RX) to phone TX & PIN 7 or PIN 8 (GND) phone battery connecter (-)
Old 02-06-2011, 07:00   #4 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,248
no need for pinfinder if connected rx tx gnd then no need for pinfinder use box rj45 port and you and connected give phone power from power supply
Old 02-06-2011, 09:27   #5 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,214
U must have to use three pins
1= RX
2=TX
3=GND
With using of Battery.
If u do not want to use battery then Use 4th pin of
Plus supply of ur rj45 cable and connect it to +Vbatt on ur fone pcb.
and do the power on of pinfinder .Plus voltage are comming out
from pin # 1 of rj45 cable of infinity .
Old 02-07-2011, 00:35   #6 (permalink)
Member: 148515
Thanks Meter: 13,692
hello!
yes, this is correct: no need pinfinder when you are using test points.
just take Rj45 cable and solder 3 wirs to PCB.
pin 2&3 to tx&rx pins
and pin8 to phone's GND
Old 02-09-2011, 00:40   #7 (permalink)
Member: 1496671
Thanks Meter: 88
thank you all... Thanks a lot guys..........
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 09:21
Page generated in 0.33469 seconds with 8 queries
