-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Please Help Urgent =infinity Team= (http://forum.gsmhosting.com/vbb/f296/please-help-urgent-infinity-team-407820/)
**RAJESH** 05-31-2007 09:51
hi..
i have CM model problem is i insert sim phone restart, w/o sim working oky.also 112 is ok...
i try to read full flash but error. and please ahich flash file sutible for thish model..???
log here..
Loading data, wait...
S/N: 1B6F:010A
Wait...
Current device: Autodetect
Done
Action: read information
Model: Autodetect
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6227, E02
Hardware version: FIREBOLT_A
Software version: FBT_1.03.1"
Software date: 2005.04.12
Barcode: 6A121287
imei: 355993005531600
Finished, time used: 16 sec
Power off phone now !
COM1 selected
Device: Autodetect
advanced flash detection active
Action: read flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6227:8A02:8A01]...
Release Power button now !
Boot Done
Initialize...
flash: 89880F00010001
flash: 89880F00000000
flash: Intel, Intel/Sharp ext [0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Check space...
operation mode: Complete detection mode
device parameters autodetection in progress..
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address[00E00000] ?
operation terminated by user
error: critical error#1 during eeprom size detection
error: can't detect eeprom address/size
detect device identification, method #1...
detection phase #1...
protocol version: 0004
2nd [standard] (or higher) generation model detected
version sw1: FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN
version sw2: FBT_1.03.1
detection phase #3...
detect device parameters finished
reading [flash[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]]...
error: data size mismatch: 00024C00, retry...
thank you...
**RAJESH** 05-31-2007 10:34
am waiting for your reply infinity team...
InfinityHelp 05-31-2007 20:24
hello!
you must be using MTK box as interface between phone and infinity soft?
**RAJESH** 06-01-2007 19:02
i have only infinity box in my new pc....
which flash version for this phone? please help....
InfinitySupport 06-01-2007 21:49
@**RAJESH**
it's always good idea to read text in Log file. Please, for future always read messages in software log window !!!
After you read text in your first message in this thread will see the answer to question that you have asked in your last message:
"which flash version for this phone?"
read errors: as you can read (I hope now you will try to read it) you can see that software found error and tried to repair it:
"error: data size mismatch: 00024C00, retry..."
you did not show full log text so nobody can expect final reading result.
finally, it's good idea to make "format ffs" if you want to reapir phone bugs (this operation was discussed in this forum many times).
one more question to you: "i try to read full flash but error. and please ahich flash file sutible for thish model..???"
Don't you think that it's good idea at least write here model name before ask this kind of questions ?
**RAJESH** 06-02-2007 08:56
sorry but no model number on cell, its china phone, only DIGITAL CAMERA write in front panel , ....i finde in support area this firmware is not aviable.i already read full flash and send...
thank you..
**RAJESH** 06-02-2007 12:34
1 Attachment(s)
InfinitySupport
finally it's good idea to make "format ffs" if you want to reapir phone bugs (this
operation was discussed in this forum many times)...
i try FORMAT FFS..now piece dead.....
COM7 selected
Device: Autodetect
Action: reset
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Check space...
operation mode: Fast detection mode
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
reading [eeprom[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]]...
file saved: backup_eeprom[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]_20070602-133347.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]_20070602-133411.B0X.bin
Finished, time used: 193 sec
Remove/Install battery now !....
restore backup and piece on..
this image china phone...
stanner_austin 06-02-2007 13:32
mostally china cpu base phone need after ffs format
long time power on ...to reset there internal data..
do ffs format again.
after that insert battery..
press power on untill u see screen blink..
post results.
phone is cent production i think
**RAJESH** 06-02-2007 14:56
post results.
hi stanner
i hold long time approx 5 min nothing...
stanner_austin 06-02-2007 15:08
Originally Posted by **RAJESH** (Post 2486862)
hi stanner
can u contact me?
i need some files..
to check and fast solution for ur problem..
InfinitySupport 06-03-2007 21:09
@**RAJESH**
1. write to phone this file:
2. now phone can power-on for sure
3. read flash from phone and send backup file to [email protected]
4. send to [email protected] this file also:
**RAJESH** 06-04-2007 12:58
Originally Posted by InfinitySupport (Post 2489669)
@**RAJESH**
ok i will send ....
thanks for your help...
InfinitySupport 06-04-2007 18:48
@**RAJESH**
I did not found any problems in your backup files.
You must make check phone hardware and make this:
3. make "format ffs"
4. press and hold phone "power" button long time
phone must be alive
**RAJESH** 06-05-2007 07:50
my phone is alive sir...
but after format ffs piece again dead. i press and hold phone 6 to 7 min nothing happen, i restore backup file phone is on but problem restart , one thing 112 is 100% working w/o sim card..when i write any backup file or format ffs always warning message ===cant detect eeprom area do you want to use standard {eeprom address {00e00000}??=== when i press no stop flashing, and press yes flashing oky but piece dead...
can you guide me any other firmware to write this phone,????
korter 08-10-2007 11:47
I have the same problem. anybody can help??
Page generated in 0.34999 seconds with 5 queries
