read backup format ffs. post log. |
Here is the log after formating COM2 [VCP0] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6227:8A02:8A01]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: D120_A112_PCB01_GPRS_MT6227_S01.D120_A112_1_07_0.B IN ver. sw2: D120_A112_1.07.0 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF flash: 89880F00010001:89880F00000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 89880F00010001:89880F00000000 Write Done Finished, time used: 43 sec Remove/Install battery now ! NOw phone is dead, but after restoring eeprom backlup all is OK, but still restarting. The phone INFo Action: read information Model: Autodetect Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: FIREBOLT_A Software version: D120_A112_1.07.0" Software date: 2005.04.12 Barcode: 71081720 imei: 352317002219196 Finished, time used: 4 sec Power off phone now ! |
u must be sure that ur installed last version of "ChineseMiracle " and try.. |
After "format ffs" you must press and HOLD phone "power" button for long time (up to 30-40 sec) |
Hi Infinity help, i try to unlock vk200 with Infinitybox and i get this status message that, can't open device check your usb connection.Help me to install usb drivers. thanks smartcoura. |
@korter read flash from this phone and send to [email protected] to check (max attach size is 10Mb) |
Mr ragesh !!! kindly make flash backup of the phone if its possible i desperatly need this file.. regards! |
Hello, I don't think it's possible to make backup from that phone. Check thread date, it's 1 year old thread. |
