Old 05-31-2007, 09:51   #1 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
Please Help Urgent =infinity Team=
hi..
i have CM model problem is i insert sim phone restart, w/o sim working oky.also 112 is ok...
i try to read full flash but error. and please ahich flash file sutible for thish model..???
log here..
Loading data, wait...
S/N: 1B6F:010A
Wait...
Current device: Autodetect
Done
Action: read information
Model: Autodetect
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6227, E02
Hardware version: FIREBOLT_A
Software version: FBT_1.03.1"
Software date: 2005.04.12
Barcode: 6A121287
imei: 355993005531600
Finished, time used: 16 sec
Power off phone now !
COM1 selected
Device: Autodetect
advanced flash detection active
Action: read flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6227:8A02:8A01]...
Release Power button now !
Boot Done
Initialize...
flash: 89880F00010001
flash: 89880F00000000
flash: Intel, Intel/Sharp ext [0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Check space...
operation mode: Complete detection mode
device parameters autodetection in progress..
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address[00E00000] ?
operation terminated by user
error: critical error#1 during eeprom size detection
error: can't detect eeprom address/size
detect device identification, method #1...
detection phase #1...
protocol version: 0004
2nd [standard] (or higher) generation model detected
version sw1: FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN
version sw2: FBT_1.03.1
detection phase #3...
detect device parameters finished
reading [flash[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]]...
error: data size mismatch: 00024C00, retry...
thank you...
Old 05-31-2007, 10:34   #2 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
am waiting for your reply infinity team...
Old 05-31-2007, 20:24   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must be using MTK box as interface between phone and infinity soft?
Old 06-01-2007, 19:02   #4 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
i have only infinity box in my new pc....
which flash version for this phone? please help....
Old 06-01-2007, 21:49   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@**RAJESH**
it's always good idea to read text in Log file. Please, for future always read messages in software log window !!!
After you read text in your first message in this thread will see the answer to question that you have asked in your last message:
"which flash version for this phone?"
read errors: as you can read (I hope now you will try to read it) you can see that software found error and tried to repair it:
"error: data size mismatch: 00024C00, retry..."
you did not show full log text so nobody can expect final reading result.
finally, it's good idea to make "format ffs" if you want to reapir phone bugs (this operation was discussed in this forum many times).
one more question to you: "i try to read full flash but error. and please ahich flash file sutible for thish model..???"
Don't you think that it's good idea at least write here model name before ask this kind of questions ?
Old 06-02-2007, 08:56   #6 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
sorry but no model number on cell, its china phone, only DIGITAL CAMERA write in front panel , ....i finde in support area this firmware is not aviable.i already read full flash and send...
thank you..
Old 06-02-2007, 12:34   #7 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
InfinitySupport
finally it's good idea to make "format ffs" if you want to reapir phone bugs (this
operation was discussed in this forum many times)...
i try FORMAT FFS..now piece dead.....
COM7 selected
Device: Autodetect
Action: reset
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Check space...
operation mode: Fast detection mode
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
reading [eeprom[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]]...
file saved: backup_eeprom[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]_20070602-133347.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log[FBT_A710_PCB01_GPRS_MT6227_S01.FBT_1_03_1.BIN]_20070602-133411.B0X.bin
Finished, time used: 193 sec
Remove/Install battery now !....
restore backup and piece on..
this image china phone...
Old 06-02-2007, 13:32   #8 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
mostally china cpu base phone need after ffs format
long time power on ...to reset there internal data..
do ffs format again.
after that insert battery..
press power on untill u see screen blink..
post results.
phone is cent production i think
Old 06-02-2007, 14:56   #9 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
post results.
hi stanner
i hold long time approx 5 min nothing...
Old 06-02-2007, 15:08   #10 (permalink)
Member: 49752
Thanks Meter: 6,085
Originally Posted by **RAJESH** View Post
hi stanner
can u contact me?
i need some files..
to check and fast solution for ur problem..
Old 06-03-2007, 21:09   #11 (permalink)
Member: 130995
@**RAJESH**
1. write to phone this file:
2. now phone can power-on for sure
3. read flash from phone and send backup file to [email protected]
4. send to [email protected] this file also:
Old 06-04-2007, 12:58   #12 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
Originally Posted by InfinitySupport View Post
@**RAJESH**
ok i will send ....
thanks for your help...
Old 06-04-2007, 18:48   #13 (permalink)
Member: 130995
@**RAJESH**
I did not found any problems in your backup files.
You must make check phone hardware and make this:
3. make "format ffs"
4. press and hold phone "power" button long time
phone must be alive
Old 06-05-2007, 07:50   #14 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
my phone is alive sir...
but after format ffs piece again dead. i press and hold phone 6 to 7 min nothing happen, i restore backup file phone is on but problem restart , one thing 112 is 100% working w/o sim card..when i write any backup file or format ffs always warning message ===cant detect eeprom area do you want to use standard {eeprom address {00e00000}??=== when i press no stop flashing, and press yes flashing oky but piece dead...
can you guide me any other firmware to write this phone,????
Old 08-10-2007, 11:47   #15 (permalink)
korter's Avatar
Member: 171307
Thanks Meter: 140
I have the same problem. anybody can help??
Please helpe me infinity team ayasir83 Infinity-Box 2 02-17-2009 14:53
Please Help Me Infinity Team For Motorola W210 Tajammul Infinity-Box 1 01-14-2009 17:28
Need flash file please help me infinity team eswar7983 Infinity-Box 9 09-22-2008 23:10
please help me infinity team its very urgent. Yuvi Infinity-Box 15 02-08-2008 12:47
i have probel with flash c118 please help me infinity team gsm4libya Infinity-Box 2 05-11-2006 12:03
Page generated in 0.25890 seconds with 10 queries
