12-25-2008, 12:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 883688 Status: Offline Thanks Meter: 12 | Flasg File For A818 Urgent Iam looking for A818 Full flash MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18 I have 3 phones in Dead condition. please anyone have this file then send it to me or give me a link to download. Regards. |
12-25-2008, 18:02 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Here is your desired flashfile. http://www.4shared.com/file/77526039...V18BINB4M.html BEST OF LUCK! yawarniazi |
The Following User Says Thank You to yawarniazi For This Useful Post: |
12-26-2008, 11:40 | #4 (permalink) |
Member: 883688 Status: Offline Thanks Meter: 12 | Hey Thanks again. Phone is working But Tuch pad is not working Correctly. Can u send me the eeprom of the phone too. I have try to repaire with infinity LCD calibration but not successfull(Tuchpad is 100% ok) Regards. |
12-26-2008, 14:14 | #6 (permalink) | |
Member: 883688 Status: Offline Thanks Meter: 12 | Quote:
i have try it too many times but its not work its ask in begining tuch the screen anyware after tuch it show upper left corner tu tuch but not work if i tuch. and there is a same kind of another phone(same brand same PCB) after switch on its shutdown automatically without sim.after switch on i can see the start up logo then shut down phone. what should be this problem? Regards. | |
12-26-2008, 14:51 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you can not calibrate touchscreen manually you need to try to make calibration via software. Do not forget that several different calibration modes can be used. other phone: did you tried to make format ffs ? |
12-26-2008, 16:55 | #8 (permalink) |
Member: 883688 Status: Offline Thanks Meter: 12 | Hi infinity Team Here is my Second phone Log when i try to make Complete ffs COM4 [VCP0] selected module v2.72 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw 2: MAUI.05C.W06.24.MP.V18, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Identification Done Write ... formatting... ..................error: code: 1400006900 .error: code: 1600006900 .............................error: code: D600006900 .error: code: F000006900 .......error: code: 5800006900 ..................error: code: 6200006900 ..........................error: code: A502000000 error: code: 0600000000 First phone still i trying |
12-26-2008, 21:32 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If your phone is in dead condition and if it is not possible to make "format" you have a good reason to check phone hardware, f.e. rehot/reball/replace flash chip or clean water inside. |
Looking for Moto L6-O2-UK flash file for PST - URGENT | lexwon | Motorola P2k | 2 | 02-10-2006 14:41 |
flasher+flash files for V690 ? urgent...need help. | the_frightener | Motorola ODM | 8 | 09-10-2005 20:37 |
Need T 65 Flash files for tornado URGENTLY | sloper | UFS2 + UFS3-Tornadoflasher | 12 | 05-28-2004 21:46 |
Need T 65 Flash files for tornado URGENTLY | kone | UFS2 + UFS3-Tornadoflasher | 2 | 03-10-2004 11:28 |
map file for me45 urgent!! | kekudo3 | Phone Unlocking Codes & Maps | 2 | 07-31-2002 23:52 |
