-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   please how to solve lenovo a3500-fl (http://forum.gsmhosting.com/vbb/f296/please-how-solve-lenovo-a3500-fl-2229965/)
trenac 05-31-2017 19:14
lenovo a3500-fl flashing done but not power on when i read info i have this error here is log
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847326404050223569C2147
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A483847326404050223569C2147
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xE0153C46B3B435A24EB61556F9542660
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : lcsh82_tb_3gfull_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3875 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000001CE280000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_lcsh82_tb_3gfull_kk.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:01
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:45
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:03
Reconnect Power/Cable!
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Break by user request!
Operation Failed
Elapsed: 00:00:13
jegan6300 05-31-2017 19:35
if u have Readed Backup file Then write it.. Otherwise no way. dead...dead....dead...
Sent from my Redmi 3S using Tapatalk
trenac 05-31-2017 19:55
no i dont have readed backup before tablet was stuck on lenovo logo then i flash with spflash tool format+download option flashing done but not power on and dont charging i try to flash with firmware from working tablet(i read with cm2 and flash,flashing was done) but same not power on
jegan6300 05-31-2017 20:02
Im also faced this problem many times. Didn't get Success.
But someone posted in fb
backup writing method is worked fo him
jegan6300 05-31-2017 20:08
One more thing if the Device is Full Dead do what ever in SPTool. But the Device is in Booting Condition Don't do format
+ download in SPTool it will brick most of the MTK devices
Just Download & Firmware UpGarde Method
trenac 05-31-2017 20:20
device was have this firmware Lenovo_A3500FL_A442_01_27_141127 before i flash.I flash device with same firmware but not succes
jegan6300 05-31-2017 20:25
Problem is eMMC Completely Erased.
Only the backup have all the needed files
trenac 05-31-2017 20:33
so no solution to revive this device i have same device in working condition but no way to revive dead one?
trenac 06-01-2017 11:16
any sugestions from infinity supporters?
Page generated in 0.18937 seconds with 5 queries
