Old 08-28-2009, 21:35   #1 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Please i need pinout coral c650
I would like to know if it is possible to unlock CORAL C650 with infinity box... if yes, what it is the pinout?
Old 08-29-2009, 20:31   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
currently it is not in supported models.
can you disassemble phone and check what MCU it is based on?
probably we can add support for it
Old 08-29-2009, 20:53   #3 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
hello!
Chip name:
NXP ARM
5231EL/147/3A
NF1071.00 26
SH654701
Bottom connector type is miniusb like v3, but this one is 2x5.
Old 08-30-2009, 18:44   #4 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Originally Posted by Hacker84 View Post
Chip name:
NXP ARM
5231EL/147/3A
NF1071.00 26
SH654701
this is the imagen from coral c650
Old 08-31-2009, 20:17   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
try to detect pinout with PinFinder like "Philips CPU".
Let's see results.
Old 09-01-2009, 01:38   #6 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Originally Posted by InfinitySupport View Post
Hello,
Let's see results.
the pinout with pinfinder i canīt find it, but opened the phone. and the pinout was that. phone has a connector miniusb like v3, but this one it is 2x5.
pin 4 = tx
pin 5= rx
pin 6= GND.
Old 09-01-2009, 01:44   #7 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Hello,
Let's see results.
Old 09-02-2009, 11:25   #8 (permalink)
Member: 148515
hello!
so finally you found pinout using pinfinder or?
Old 09-03-2009, 22:26   #9 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
hello!
i have not pinfinder, i had to open the phone and find the tx and rx.
The Following User Says Thank You to Hacker84 For This Useful Post:
Old 09-23-2009, 23:33   #10 (permalink)
jesedavidfrv's Avatar
Member: 914317
Sonork: 100.1601159
Thanks Meter: 66
plese help me i have 1 pcs this phone for unlock need solucition
Old 10-16-2009, 11:29   #11 (permalink)
Member: 210669
Thanks Meter: 97
coral c655 pinout software version: 1.17
cable type: 2x5 (L10C)
platform: MT: MT62xx (autodetect)
searching adapter at COM10...
adapter found, version: 2000
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:2 Tx:1
time required: 5 sec
Power Off !
Power On !
can read user code
COM10 [VCP0] selected
module v2.73
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001A03:000F
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: C2016HW_2.7_EU_DIG_T4S4
Version: C2016_EU
detecting structure #2...
0 done
44 byte(s) read
imei: 35742902035501
connection Ok
detecting structure #1...
0 3 4 5 6 7 8 9warning: wrong packet cs
12 done
157 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 37 sec
Remove/Install battery now !
but can't unlock sp
Old 10-16-2009, 21:11   #12 (permalink)
Member: 148515
pins: 10, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:2 Tx:1
Power Off !
Power On !
can read user code
module v2.73
Action: read codes
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001A03:000F
Connecting, wait...
Date: 2006.06.14
Version: 1.0
Version: C2016_EU
0 done
44 byte(s) read
connection Ok
12 done
157 byte(s) read
Phone lock: Off
Network lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
but can't unlock sp
hello!
make full backup by using "read full flash" operation.
after this is done- make format FFS complete
Old 06-10-2010, 00:44   #13 (permalink)
rudyandremely's Avatar
Member: 108193
Thanks Meter: 70
hello!
but we are talking about coral 650 or 655?...
Old 06-12-2010, 13:51   #14 (permalink)
Member: 148515
hello!
complete format should work for any phone.
if SP lock flag is keept in eeprom.
Please i need pinout coral c650? Hacker84 Infinity-Box 0 08-29-2009 00:02
Please help, need pinout AlexRom51 Infinity-Box 1 01-27-2008 19:33
Please i need pinout for Alcatel C55x C630x karikari FuriousGold 1 09-24-2007 15:08
Please !!! I need pinout maxon epsilon SEWON GMX@cool Various 14 09-19-2004 15:02
PLEASE i need pinouts for A2618s duda Old Ericsson Phones & Sony Phones 8 04-08-2001 19:51
Page generated in 0.29699 seconds with 9 queries
