10-23-2014, 20:58 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/MediaTek v1.05 - Nokia 108/130/220/225 support Nokia 108/130/220/225 support MediaTek SP Platform Other: FlashInit improved Compile Info extraction improved FlashID database updated MediaTek FP Platform New CPU/Models supported: Nokia MT625A: Nokia 108 (RM-944, RM-945), Nokia 220 (RM-969, RM-970, RM-971) Nokia MT6260: Nokia 130 (RM-1035, RM-1036, RM-1037), Nokia 225 (RM-1011, RM-1012, RM-1043) Supported Features: Check/Read Info Format FS (Safe Format/Reset Settings) Other: Required to use special drivers for Nokia MTKx phones (uploaded on support) Flash Read/Write is useless due security protection Last edited by YellowBoss; 06-25-2020 at 11:05. |
10-25-2014, 20:32 | #3 (permalink) | |
I think you cn unlock these models with help of our Server: BB5 Easy Service Tool [BEST] - Functions | |
11-02-2014, 09:11 | #5 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | Card found: S/N Chinese Miracle II [MTK module] v 1.05 Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Break by user Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read error Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Read PatternLock [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Read PatternLock [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Not supported FlashType for this operation Done! Elapsed: 00:00:01 Reconnect Power/Cable! |
