08-09-2008, 07:40 | #1 (permalink) |
Major Poster Join Date: Dec 2007 Location: Chennai ,Tamilnadu , INDIA
Member: 649344 Status: Offline Thanks Meter: 7 | please need bluetooth jb2008 firmware : E553_B2_E553_GPRS_MT6226_S01.01_1.BIN 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: B362F7AA identification#1 protocol ver: 04 ver. sw1: E553_B2_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_B2.01.1, 55007B0F ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done Finished, time used: 145 sec Remove/Install battery now ! |
08-11-2008, 10:56 | #4 (permalink) |
Member: 649344 Status: Offline Thanks Meter: 7 | for jd2008 firmware use found jd2008 firmware in firmware support name E553_B2ARAB_E553_GPRS_MT6226_S01.01_1__N95_not_sli der_16m_En_Ru_Ar.B0M its working thank u |
NEED!!![E75UVWE1.TEST] Firmware!!! HELP!!! PLEASE!!! | moldovan | Trident/AGERE Platform | 9 | 08-10-2004 05:18 |
new firmware with RU language for SENDO M550, please need HELP!!!! | Havjan | Various | 0 | 01-24-2004 04:54 |
Need T610 R1l Firmware For Use With Div Please Help. | EndlessConnections | Sony Ericsson | 5 | 11-18-2003 02:15 |
please need help on bluetooth problem | NNN | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-29-2003 02:07 |
