Please SOLVE and ADD This Firmware MYPHONE S21 Quote:
module v2.83 Action: reset settings Model: MyPhone-S21 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:29BA:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: T01_23.07A.W0736.MP.FMCAM-FTP_V0.09 Version: Tinno23_07A_HW 44 byte(s) read imei: 35439101934277 connection Ok building list... done items to clear: 158 warning: wrong packet cs items cleared: 158 of 158 building list... done items remains: 0 Finished, time used: 36 sec Remove/Install battery now ! Quote:
COM7 [VCP2] selected module v2.83 Device: MyPhone-S21 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:29BA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6A4B4 459.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN_18ECF8D6].rpl ==================== New firmware detected (v.2.83, database date: unknown): TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 6A4B4459 identification#1 protocol ver: 04 ver. sw 1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN ver. sw 2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.09, 290713E7 ffs offset/size: 00800000/00800000 ffs address assigned: 00800000 security area (code #1) check... security area (code #1) fixed detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__ffs... file saved: C:\Program Files\InfinityBox\MModule\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__ffs_20090817-094430.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting parameters to apply patch area 0/... .................................................. .............. error: area 0/ can not apply patch Special operation Done Write ... flash: 01227E22202200:2AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__system_log_6A4B4459_18ECF8D6_20090817-095426.B0X.bin Finished, time used: 959 sec Remove/Install battery now ! Quote:
Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 354391019342778 Model: MyPhone-S21 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:29BA:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: T01_23.07A.W0736.MP.FMCAM-FTP_V0.09 Version: Tinno23_07A_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 44 byte(s) read verification... verification done: 35439101934277 Finished, time used: 15 sec Remove/Install battery now ! |
COM7 [VCP2] selected module v2.84 Device: MyPhone-S21 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:29BA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd PL127J D 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6A4B4 459.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN_18ECF8D6].rpl ==================== New firmware detected (v.2.84, database date: unknown): TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 6A4B4459 rom info protocol ver: 04 ver. sw 1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN ver. sw 2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.09, 290713E7 ffs offset/size: 00800000/00800000 ffs address assigned: 00800000 startup code area #1 check... startup code area #1 fixed detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__ffs... file saved: C:\Program Files\InfinityBox\MModule\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__ffs_20090817-101714.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting parameters to apply patch area 0... .................................................. .............. error: area 0 can not apply patch Special operation Done Write ... flash: 01227E22202200:2AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_09__system_log_6A4B4459_18ECF8D6_20090817-102056.B0X.bin Finished, time used: 579 sec Remove/Install battery now ! |
try to download this file in support area sir MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_08_En.B0M.bin flash and unlock no need to change IMEI GOLDLUCK:D |
==================== New firmware detected (v.2.84, database date: unknown): TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_09.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== P.S. In year 2008 well known British scientists have made a big research about text reading and brain thinking possibilities and in their public report one of the reason of thinking facilities decreasing was: ".... people lost their mind after many repeated posts with words like "ha-ha-ha" and "ho-ho-ho", but "ha-ha-ha" is more dangerous. ... " |
Ok sorry for the word hahahahaha hohohoho but this like a hummmm Already solved by this files: MyPhone-S21_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W 0736_MP_FMCAM-FTP_V0_08_En.B0M.bin Myphone-S21_ffs_02.B0E.bin Thanks for reporting |
Hello, Do you have original full flash backup ? If you want to avoid this kind of problems in future please always follow advices given by software: Code: ==================== |
ok uploading and support ver 09 theres a simple trick if phone ver 8 no need flash but if ver 6 7 and 9 need flash then unlock |
Hello, Thanks ! We will check this firmware and add support for it in next update. |
