02-27-2008, 18:31 | #1 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | Please Support Repair Imei Of Kg110 & Other Lg Handset plz. give the repairing of imei in kg110 & other similar handset please make it asearly as possible b'cause v r loosing customer thanks & wbr |
03-10-2008, 20:50 | #2 (permalink) |
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | @infinity support sir i'm deparatly waiting for ur update for rebulding of imei of kg110 & other lg handset b'cause the call drop problem only solve through this method only |
03-11-2008, 05:50 | #5 (permalink) |
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | sir i tried all the solution posted on the support forum.write full falsh ,repair eeprom,upgraded the flash version even wrote the back up eeprom of good handset but no improvement if imei is corrupted then the call drop problem will not remove.plz. add support of rebuilding imei that will solve the problem |
03-11-2008, 08:37 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | i an also face this problem i try lot of time bt its no working.... http://www./showthread.php?t=500300 |
03-11-2008, 11:23 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sabby_singh @THE ANT Dear Boys, Please, read my previous message with instruction: http://www./showpo...92&postcount=3 Files available in support area in \flashfiles\LG\KG110\full_flash folder |
03-11-2008, 19:07 | #9 (permalink) | |
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | Quote:
& i'm very sorry not reading ur post carefully i will check this & post u result. once again thanks & wbr | |
03-12-2008, 06:00 | #10 (permalink) |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | sorry for last post bc i did not read yrs this post thanks for this solution i will check this & post u result once again infinity box is the hero of india............... the ant........ |
BAD IMEI OF KG110 & Call Dropped......... | sursuri | Infinity-Box | 25 | 08-31-2010 19:08 |
I Can't repair IMEI of LG KP107 | BackSlash_cu | Z3X-Team Products | 1 | 01-10-2010 20:08 |
How to Repair IMEI of LG CU400 | bornagaintobe | FuriousGold | 2 | 10-15-2009 22:27 |
How to repair imei of LG u990 | mobile_master20 | FuriousGold | 3 | 06-02-2009 10:40 |
Can't Change Imei Of KG110........... | dil_PAKISTANI | FuriousGold | 0 | 08-27-2008 11:20 |
