07-19-2016, 09:34 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Qmobile M95 flashing Dead ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 7/3/2015 2:38:50 PM Project Ver : KOT49H 14B_test-keys Model Ext : QMobile M95 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:22 Reconnect Power/Cable! Finish at : [7/19/2016 / 11:53:32 AM] Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Start at : [7/19/2016 / 11:55:44 AM] Operation : Flash [ v1.19 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... [FlashProc] : Error with code 0x0280 then i format and again flash but same problem stuck on flashing ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... [FlashProc] : Error with code 0x0280 Mobile is problem Virus .... erase done Chinese Miracle II [SPD module] v 1.19 Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Operation : Flash Erase [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... Format finished! Reflash phone with normal FW now! Elapsed: 00:00:47 Reconnect Power/Cable! Last edited by saqib2009; 07-19-2016 at 09:42. |
07-19-2016, 13:38 | #6 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | flash ic test result here and battery is charged .... 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:16 Reconnect Power/Cable! |
07-19-2016, 14:06 | #7 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 35
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | QMobile M95, this phone have two versions... Please look at the back battery sticker if there is "V2" exist, or if you are flashing with V1 then try with V2, if you are flashing with V2 then please flash it with V1.. |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
07-19-2016, 14:42 | #8 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | i cheq already battery sticker only M95 not version v2 i flashed this version SP7731GEA_scx35_sp7731gea_4.4.3_KOT49H_14B_test-keys but writing eror show can u give me the link m95 v2 ejazat |
07-19-2016, 14:48 | #9 (permalink) | |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Quote:
Log for V2: Code: Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : scx35_sp7731gea_hd Device CPU : sp7731gea_hd Device IntName : scx35_sp7731geaplus_hd_dt Device Version : 4.4.3 Device Compile : 20/11/2015 10:53:30 Device Project : KOT49H 14B_test-keys Device ExtInfo : QMobile M95 QMob M95 (V2-CM2) | |
The Following User Says Thank You to EjazATF For This Useful Post: |
07-19-2016, 14:48 | #10 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | set was on only virus and i cheq info in on condtion here is log FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 7/3/2015 2:38:50 PM Project Ver : KOT49H 14B_test-keys Model Ext : QMobile M95 ExtraInfo : HWInfo not exists, normal phone then i flash stuck on writing software then not responding then set dead |
07-19-2016, 16:34 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Looks like it some kind of HW problem. Try hold both volume keys when flashing phone. But charge battery first completely. And hold keys during whole flashing process. |
07-19-2016, 16:48 | #13 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | set is brand new not open problem is **** hot virus i flash writing 99% and software hang and not responding show the erer come and set dead now set detect but writing 1% stuck software and erer come charge batery hold key all u r method try but not writing flash erase done detect only writing problem i cheq v1 v2 but same |
07-19-2016, 17:05 | #15 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | i already send service center for warranty claim this is last decision thanks jaydi u help me i hope keep it up and more stable update spd exe ....without root full suport add spd new phone |
