04-03-2018, 16:27 | #3 (permalink) |
Insane Poster Join Date: Mar 2016 Location: Mumbai
Member: 2539333 Status: Offline Thanks Meter: 21 | Card found : S/N : BBA96A58 , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [01-04-2018 / PM 01:43:52] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! |
04-03-2018, 16:36 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
good luck | |
The Following User Says Thank You to gracy_elec For This Useful Post: |
04-03-2018, 17:45 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | DA files for different models available for download. See support area/-community-uploads/MTK.DA folder |
