02-08-2008, 10:48 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: GREECE Age: 52
Member: 84724 Status: Offline Thanks Meter: 31 | Ploblem after flash KE970 ANY HELP??? THANKS!!! |
02-08-2008, 11:08 | #3 (permalink) |
Member: 84724 Status: Offline Thanks Meter: 31 | LONG!!! Code: ==== log opened: [2/8/2008 10:21:21 AM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.38 S/N: 0B4D:010C Wait... Current model: IMobile-100 Ready Current model: LG KE970 Loading file v.02... KE970P40-07-V10e-***-XX_APR-05-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua[1].B1M.bin loaded Loading file v.02... KE970P40-07-V10h-***-XX_MAY-11-2007_file_system[1].B1S.bin loaded COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080208-102509.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080208-102555.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080208-102558.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080208-102600.B1E.bin reading [eeprom-dyn_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35030526000000100_20080208-102625.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 3458 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080208-112718.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080208-112722.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080208-112724.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080208-112727.B1E.bin reading [eeprom-dyn_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35030526000000100_20080208-112753.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 57 sec ==== log opened: [2/8/2008 11:31:04 AM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.38 S/N: 0B4D:010C Wait... Current model: IMobile-100 Ready Current model: LG KE970 Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KE970P40-07-V10e-***-XX APR 05 2007+0 imei: 00000000000000000 Done Finished Loading file v.02... KE970_repair_eeprom_complete_09[1].B1E.bin loaded COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080208-113250.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080208-113252.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080208-113254.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080208-113256.B1E.bin reading [eeprom-dyn_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35030526000000100_20080208-113322.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Eeprom Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 61 sec COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: unlock Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080208-113426.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080208-113429.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080208-113430.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080208-113432.B1E.bin reading [eeprom-dyn_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35030526000000100_20080208-113458.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 0195 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 50 sec COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080208-113614.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080208-113618.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080208-113620.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080208-113622.B1E.bin backup critical area Done Check memory... Check memory Done Write... Writing: Eeprom Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 22 sec Loading file v.02... KE970P40-07-V10e-***-XX_APR-05-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua[1].B1M.bin loaded Loading file v.02... KE970P40-07-V10h-***-XX_MAY-11-2007_file_system[1].B1S.bin loaded Loading file v.02... KE970_repair_eeprom_complete_09[1].B1E.bin loaded COM1 [VCP0] selected Device: LG KE970 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading |
02-08-2008, 19:26 | #7 (permalink) |
Registered User Join Date: Dec 2007 Location: fazal Haroonabad Pakistan Age: 46
Member: 650213 Status: Offline Sonork: 100.1581739:333 Thanks Meter: 133 | bro from any flash to any mobile on inifinity , first u use these options user code/unlock reseting and format complete. its do well work than others these options , to solve problems |
heeeel furious team problem after flash ke970 | >>the boos<< | FuriousGold | 2 | 12-30-2009 06:19 |
After flash KE970, help!! | elmatrix | LG | 0 | 10-15-2008 10:57 |
After flashing KE970, help!! | elmatrix | VygisToolbox | 1 | 10-15-2008 01:19 |
strange problem after flashing KE970. | snowtown | VygisToolbox | 5 | 09-27-2008 09:21 |
Hang after flash -ke970 | .:GSM International:. | VygisToolbox | 3 | 04-18-2008 23:26 |
