Old 02-15-2009, 06:15   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
pls explain .what i have to do now ?.
COM39 [VCP0] selected
module v2.77
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9903:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.20EA5D3B.[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN_98BD6122].rpl
New firmware detected (v.2.77, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 20EA5D3B
identification#1 protocol ver: 04
ver. sw 1: MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN
ver. sw 2: A521_L8EN_LCD2_132_080522, DD9E4267
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN]_20090215-111136.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_20EA5D3B_MTK25_06B_PCB01_GPRS_MT6225_S00 .A521_L8EN_LCD2_132_080522.BIN_98BD6122_20090215-111157.B0X.bin
Finished, time used: 139 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
hn
Old 02-15-2009, 06:16   #2 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
i have lot of same set with this problem ,
all are dead .
pls help infinity team
Old 02-15-2009, 13:32   #3 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
i am waiting...................
Old 02-15-2009, 15:20   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what was initial phone problem?
Old 02-15-2009, 17:17   #5 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
set is dead ...............
i have some same model phone
all are same problem
Old 02-15-2009, 17:32   #6 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 112
Do you create flash backup after do format ffs actions???
Old 02-15-2009, 21:01   #7 (permalink)
Member: 148515
hello!
try to flash with this files:
flashfiles/ChineseMiracle/_MT6225/MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_108_0801 23___5310_16m_En_Ru_Fr_Es_Th_Vn_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12_Nokia-5300-XpressMusic_16m_En_Ru_Fr_Id_Th_Vn_Farsi_Ar.B0M.bin
Does ipmart need just money no matter how they get it and what they have to do to get Miangee911 ipmart WebShop 0 03-16-2010 07:45
GX17 - what I have to do with fuse ??? *Diablo* Sharp 0 08-26-2007 14:13
what i have to do SALNAI Smart-Clip 4 08-05-2007 09:47
What else do I have to do to get my credit? ozzyroger KULANKENDI Server 1 05-22-2007 15:06
what do i have to do to unlock a V600i? kev hancock Sony Ericsson 2 02-15-2007 01:51
Page generated in 0.23480 seconds with 9 queries
