12-09-2007, 15:16 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there is many 6300-type phones. please specify wich connector does it have and where is located GND pin. also, when you get pinout- start from formating FFS, leave flashing to last thing to do |
12-10-2007, 06:22 | #5 (permalink) |
Freak Poster Join Date: May 2006
Member: 283134 Status: Offline Thanks Meter: 32 | ok,pin-out i did it by my self,the problem is phone is blinking and it dosnt formatt ffs.i need flashfile for this phone,theres no flashfile in support area. anyone has flashfile CECT 6300R? |
01-03-2008, 00:49 | #9 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: in-house
Member: 239484 Status: Offline Thanks Meter: 14 | Quote:
but I did one here 6300R CECT the pin out you told not working is the correct one.. heres the logs and picture of the right pin out.. my 6300R fixed.. | |
01-11-2008, 04:45 | #11 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Manila Age: 48
Member: 42049 Status: Offline Thanks Meter: 7 | Hey guys in support where is the flash file for this kind of phone in the support area? i have a unit here that is stuck in start up only. I do the format ffs and it all goes well except for the frequent restarting or sometime turning offf of the phone. Do you think this phone need full flashing or what? hardware problem maybe? |
01-11-2008, 08:24 | #12 (permalink) | |
Here is detailed instruction: http:///vbb/showthread.php?t=476373 Flash files is in support area in "Chinese Miracle" folder. | |
01-12-2008, 05:37 | #13 (permalink) |
Member: 42049 Status: Offline Thanks Meter: 7 | heres the detailed info of my cect 6300R phone COM4 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:30C1:C27A high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] (or higher) generation security area#1 Ok security area backup saved: id.A1FBD338.[RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_4T03 S0829.BIN_42792443].rpl identification#1 detection finished device-id: A1FBD338 identification#1 protocol ver: 04 ver. sw1: RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_4T03 S0829.BIN ver. sw2: R6300_03_0.4T03S0829 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom area in 1 chip(s)... flash: 98004900000002:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detecting structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete eeprom element #1 detected ok file saved: backup_system_log_A1FBD338_RATECH26_06A_PCB01_GPRS _MT6226_S01.R6300_03_0_4T03S0829.BIN_42792443_2008 0112-113259.B0X.bin Finished, time used: 124 sec Remove/Install battery now ! i find the ratech 6300 file under the MT6205-MT6227 folder |
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? | vintel | Infinity-Box | 4 | 03-07-2010 11:29 |
pls pls pls help me for e65 | sidah-gsm | BB5BOX | 4 | 01-28-2008 10:16 |
Pls Pls Pls Help Me | ctg60000 | WD2 & APE (Symbian Phones) | 3 | 10-31-2006 12:50 |
PLS PLs PLS help me u8120 v102 hi red box help help | sunnyc | LG | 1 | 11-17-2004 18:34 |
Pls help me my siemens c-35 keypad Hang pls help me | varma raj | x1x to x45/x50 | 1 | 06-17-2003 10:50 |
