08-13-2009, 04:04 | #1 (permalink) |
Registered User Join Date: Dec 2007 Location: fazal Haroonabad Pakistan Age: 46
Member: 650213 Status: Offline Sonork: 100.1581739:333 Thanks Meter: 133 | PLs help durringt format set dead. COM14 [Serial2] selected module v2.73 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C803:000A Connecting, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13warning: wrong packet cs 14 15 16 17 18 19 20 21 22 23warning: wrong packet cs 24 25 26 27error: detection failed (28 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 8/12/2009-3:12:55 AM Continue with this imei ? ==== log: [8/12/2009 3:13:15 AM] ==== COM14 [Serial2] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 350448011234561 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C803:000A boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 05 ver. sw 1: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2.BIN ver. sw 2: MAUI.08B.W08.52.MP.V2, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... detecting ffs structure pass 2... ........................... detect standard fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 imei default found: 00FF55550000F0 Patch required data Done Special operation ... Special operation Done Write ... flash: 98000300000001:18E59F00000000 flash: 98000300000001:18E59F00000000 Write: imei error: error# 0000FFFF error: flash write error: 00BA0000:00002000 error: can't write required area Write Fail Finished, time used: 129 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! we flashed with this file HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_16m_En_Es_Pt.B0M now set in white screen and function working ok pls inifinity help urgent |
Can anybody help nokia 1255 set dead.when i flash. | debmobile | Nokia CDMA | 3 | 06-01-2009 17:11 |
after format set dead | narendrasanju | SpiderMan | 2 | 06-25-2008 18:21 |
Infinity Team i want help. after format mobile dead | IkaMazini | Infinity-Box | 3 | 04-10-2008 14:41 |
Pls Help me For gd92 dead | YaSSaX | Panasonic | 0 | 06-01-2001 18:47 |
