05-21-2010, 17:43 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | pls help infinity team formet log : COM6 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:3731:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9EF3AC28.[PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319B_ 02_YJ319AT_R1_0_26_1.BIN_42B8ADE5].rpl rom info detection finished ==================== New firmware detected (v.3.13, database date: 25.04.2010): PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319B_ 02_YJ319AT_R1_0_26_1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 9EF3AC28 rom info ver: 04 sw version: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319B_ 02_YJ319AT_R1_0_26_1.BIN project-id: A319B_02_YJ319AT_R1.0.26.1, E5ADB842 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFF0026:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0026:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0026:2088C400000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\P ROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319B_0 2_YJ319AT_R1_0_26_1__system_log_9EF3AC28_42B8ADE5_ 20100521-220720.B0X.bin Finished, time used: 1 min 13 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-21-2010, 19:32 | #2 (permalink) |
Insane Poster Join Date: Aug 2008
Member: 828078 Status: Offline Thanks Meter: 5 | Flash with your backup file. But you must have created backup file before your modification file system. Please do it always. And then go to service tab and use "User/lock code" button. |
05-24-2010, 07:38 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to flash it with this version: flashfiles/ChineseMiracle/_MT6223/PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319B_ 09_Q1MU_R1_0_31_2_16m_En_Ru_Th_Vn_Ar.B0M.bin |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
