04-23-2008, 19:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 681183 Status: Offline Thanks Meter: 165 | ZTE 125 PinFinder But Don't Work |
04-23-2008, 20:42 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must try to reverse pins as well as swap them. select cable L8A, set data pins 1:2, set power On, try to connect. if fail: push reverse, try to connect if fail set data pins 2:1 and repeat if not work: reverse after you find correct pinout pinout: save it for future work by "pinout saving feature" |
zte 125 unlocked but still locked | gsmservices | Infinity-Box | 9 | 06-21-2008 10:15 |
ZTE 125 unlock but ...... | asco777 | Infinity-Box | 5 | 04-08-2008 08:26 |
Unlock codes read but don't work? | goodbyegti | NEC | 1 | 05-14-2005 20:26 |
Unlock codes read but don't work? | goodbyegti | NEC | 0 | 05-14-2005 19:55 |
I have Sagem unlock cracked by GSM Brothers but don't work!!!1 | florinmar | Infineon C16X M51 & ARM7 M52 BASED | 0 | 04-01-2002 17:06 |
