pls help n958 display reverse i received n958 with hanging problem ...after flash display reversed....:confused: |
Try to flash phone with other but similar firmware version. |
sorry which file i have to select .... i tried with E559_YP1F10DOVTRI_E559_GPRS_MT6225_S00.V60_01_0__S ooy-Ersson_K530i_16m_En_Ru_Fr_Es_De_Th_Vn_Cn_Tr_Ar.B0M .... but i get plane display... this is the log..... COM6 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CD03:0006 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: E559_YP1F10DOVTRI_E559_GPRS_MT6225_S00.V60_01_0.BI N ver. sw 2: E559_YP1F10DOVTRI.V60.01.0, 00000000 ffs offset/size: 00E00000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 71 sec Remove/Install battery now ! :confused::confused::confused::confused::confused: |
not succeess ...this is the log COM6 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CD03:0006 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: E559_YP1F10DOVTRI_E559_GPRS_MT6225_S00.V60_01_0.BI N ver. sw 2: E559_YP1F10DOVTRI.V60.01.0, 00000000 ffs offset/size: 00E00000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 71 sec Remove/Install battery now ! |
hello! what was your original software version? |
