Old 11-15-2008, 16:34   #1 (permalink)
Member: 378776
Thanks Meter: 20
pls help sigmatel v88 no display
pls help me the msg come
COM3 [VCP0] selected
module v2.68
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: repair security area
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:BC03:0001
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
Finalization Done
Finished, time used: 81 sec
Remove/Install battery now !
Old 11-15-2008, 19:57   #2 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
What is the original firmware name?
Old 11-15-2008, 21:44   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@rajivmobil
You have a phone with completely erased flash chip.
You need to flash phone to make it working.
Pls help me to solve display light problem of rd3000 sumeet922 LG Hardware Repair 9 08-29-2016 08:20
pls help! sigmatel s4 pin out rashad-a Chinese Models & Cloned Phones 3 09-12-2008 18:12
Help - Sigmatel V88 86Gaz Chinese Models & Cloned Phones 0 06-19-2008 13:42
pls help,lenovo p708 no display after flash hall Infinity-Box 5 04-20-2007 10:47
Pls help with mot v66 display settings thecult Motorola P2k 4 07-20-2004 10:34
Page generated in 0.15847 seconds with 10 queries
