04-17-2007, 08:21 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 200467 Status: Offline Thanks Meter: 12 | pls help unlock C139(airtel) COM9 selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Err: boot failure[02]: Release Power button ! Connect Fail Failed ! Finished, time used: 29 sec Remove/Install battery now ! I am using T191 cable the sw version is 1.3.29 pls any help |
04-17-2007, 11:35 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | also some info: C115, C116, C139 bad connection: http://forum.gsmhosting.com/vbb/showthread.php?t=309557 http://forum.gsmhosting.com/vbb/showthread.php?t=290589 http://forum.gsmhosting.com/vbb/showthread.php?t=271431 Please, read instruction in yellow window (you will see it for sure when you start software). |
04-18-2007, 05:34 | #5 (permalink) |
Member: 200467 Status: Offline Thanks Meter: 12 | Thanks for the reply. But the problem is not solve I also tryed the connection :method 4 but getting the same error.Also tryed using the new cable but no use.I just wanted to ask do I need the cut the track as shown in the documentation to do the unlock.Or just the direct unlock like J100(Airtel). |
04-18-2007, 07:01 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. make direct unlock. 2. It looks like you did not tried to read my links in my previous message, please, read this: http://forum.gsmhosting.com/vbb/show...92&postcount=4 3. if nothing help: read FAQ thread, f.e. http://forum.gsmhosting.com/vbb/showthread.php?t=310686 or http://forum.gsmhosting.com/vbb/showthread.php?t=334357 |
pls help unlock Nokia 6100 | Lugo | Phone Unlocking Codes & Maps | 4 | 04-30-2003 17:25 |
Pls help unlock Nokia 3530 | maxdu | Phone Unlocking Codes & Maps | 2 | 04-29-2003 19:27 |
Pls help unlock MW3026 | ivanich | Phone Unlocking Codes & Maps | 0 | 02-13-2003 04:24 |
M35v20 locked....pls help unlock it !!!! | GsmNut | x1x to x45/x50 | 2 | 12-30-2002 09:29 |
Pls help unlock my gd90! | unidencek | Panasonic | 3 | 08-14-2001 10:10 |
