08-26-2010, 08:28 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: india Age: 40
Member: 135518 Status: Offline Sonork: 1605927:cellcomna Thanks Meter: 56 | pls help for zte orange lisbon i have some error COM6 [VCP0] selected module v3.54 Device: ZTE-X670 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0103:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.04B61 483.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rom info detection finished device-id: 04B61483 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X670_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA111__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X670_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA111__ffs_20100826-125645.B0E.bin flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X670_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA111__system_log_04B61483_C07F45 09_20100826-125757.B0X.bin Finished, time used: 7 min 31 sec Remove/Install battery now ! how to solve this problem thank |
08-26-2010, 13:20 | #2 (permalink) | |
At first try to select correct model name Orange-Lisbon and repeat unlock process. | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
09-07-2010, 17:30 | #4 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1388817 Status: Offline Sonork: wrmsj00 Thanks Meter: 0 | I have Orange Lisbon phone but not sure how to get hold of the unlock code. The imei is: xxxx. The model number is: ZTE-G X670. many thanks Last edited by YellowBoss; 09-07-2010 at 17:36. Reason: imei removed |
10-18-2010, 23:31 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You are always welcome. Just check Infinity-Box - About and you will see actual list of supported models. |
11-03-2010, 15:51 | #10 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | here is the procedure how to unlock this x670 phone, http://forum.gsmhosting.com/vbb/f296...hings-1130639/ |
The Following 3 Users Say Thank You to malikzahidawan For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
