pls i need auth file to backup file to tecno ca6 pls help after the custom modified ca6 da file my phone compromised and cannot boot but i was able to backup firmware i needed custom auth to write back the firmware. |
...therefore here is the factory file+tool or use sp flash tool tested by me TECNO CAMON CM CA6 OFFICIAL FACTORY FIRMWARE |
fail to flash with cm2 says this frimware will kill phone we need signed frimware |
GOOD LUCK |
oopps after read my post one of this thread person make corection they have upload the firmware which i already upload the firmware on ios support area ones again oopps good luck |
@gracy elec, pls i really need ur help on this. i messed up two ca6 devices when trying to remove frp. i av downloaded ur file from support. but cm2 says this firmware will kill this phone. how did u help others. help me too. |
just download firmware from nck support are 100 percent tested |
Just for your information this is Infinity-Box section. So next time don't advertise about other box. Br. Infinity Box Team. |
To fix this problem just used correct da file and then connect cable without holding any buttons that's all. Most important for repairing of imei |
