07-07-2006, 21:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: bossunlocker Age: 48
Member: 21732 Status: Offline Sonork: 100.75816 Thanks Meter: 218 | pls i need repair bad cut in c117 pls i need repair bad cut in c117 after cut then flash i cant flash phone may be make a deep cut pls help |
07-07-2006, 22:25 | #3 (permalink) |
Member: 21732 Status: Offline Sonork: 100.75816 Thanks Meter: 218 | pls what this error COM23 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Err: boot[03]: 1BF60200520153 Release Power button ! Connect Fail Finished Remove/Install battery now ! Time used: 8 sec |
07-07-2006, 22:55 | #5 (permalink) |
Member: 21732 Status: Offline Sonork: 100.75816 Thanks Meter: 218 | many thx all but Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... UNKNOWN FLASH: 0020:88CE/0020:88CE Check Space Fail Finished Remove/Install battery now ! Time used: 9 sec |
07-08-2006, 15:51 | #6 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | Quote:
hi bro use lastes Repair Modul coz this new flash chip test and replay salam | |
pls.i need this file.not in support | GOODNESS | Infinity-Box | 5 | 12-12-2008 03:03 |
repear bad cut in simens | raoul plus | Siemens Hardware Repair Area | 2 | 07-18-2008 13:28 |
siemens a31 repair bad cut | nkakanou | Siemens Hardware Repair Area | 14 | 09-12-2006 06:53 |
Repair bad cut a65 & a70 | fadhel | Siemens Hardware Repair Area | 2 | 08-24-2006 07:26 |
Need A52 bad cut repair solution | .:Kuku:. | Siemens Hardware Repair Area | 3 | 05-06-2005 22:44 |
