pls i need urgent reply hello to all ma trying to flash lg gx200 with infinity but after phone only show logo on it pls what show i do COM23 [VCP6] selected module v3.73 Device: LG-GX200 Checking data, wait... Action: write flash NAND write: Firmware GX200_ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01. GX200-00-V10F-CIS-XX-JAN-09-2010_En_Ru_Ro_Kz_Lt_Lv_Ee_Ua.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: ARIMA6235_GEMINI_09A_BOOTLOADER_V005_MT6235B_GX200-00-V10F-CIS-X nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0007]: 00EC:00F100000095 [SAMSUNG] K9F1G08X0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: GX200-00-V10f-AME-XX-MAR-28-2010 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ARIMA6235_GEMINI_09A_BOOTLOADER_V005_MT6235B_GX200-00-V10F-AME-X nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01.GX200-00-V10F-AME-XX-MAR-28-2010.BIN project-id: GX200-00-V10f-AME-XX-MAR-28-2010, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: ARIMA6235_GEMINI_09A_BOOTLOADER_V005_MT6235B_GX200-00-V10F-CIS-X nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . write core... Disconnect... done Finished, time used: 16 min 6 sec Remove/Install battery now ! |
Bro try to format in safe mode when phone tries to power on then quick unplug the cable Post here if it help you. Thanks |
Did you tried to flash phone with another flash files from support area ? |
when u put on the phone it only shows on u see only the lg sing on it then goes off and the try to download from support to flash but still the same problem am really disturber i don't know what to do pls need urgent reply thank u |
