02-17-2017, 14:53 | #1 (permalink) |
Major Poster Join Date: May 2016 Location: Pakistan Lahore
Member: 2573165 Status: Offline Thanks Meter: 54 | Arex A10i Flash File / Factory File Read Done... Arex A10i Flash File / Factory File Read Done With Great Tool CM2... Here is File Info... MT6582__alps__lcsh82_cwet_kk__lcsh82_cwet_kk__4.4. 2__ALPS.KK1.MP1.V2.10 Here is Read Info... Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D4201CACCDC6AB171 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201CACCDC6AB171 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x3D19A9768D36C70F9BF6F4B418D92C26 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : alps ProdName : lcsh82_cwet_kk ProdModel : lcsh82_cwet_kk Device : lcsh82_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_lcsh82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / lcsh82_cwet_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1016 MiB Scatter saved to : C:\Users\khizar\Desktop\MT6582__alps__lcsh82_cwet_kk__lcsh82_cwet_kk__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:04:55 Here is Pic... Br Haseeb Ur Rehman |
The Following 2 Users Say Thank You to Haseeb Umer For This Useful Post: |
02-17-2017, 15:06 | #2 (permalink) |
Member: 2573165 Status: Offline Thanks Meter: 54 | Arex A10i Imie Repait Done... Arex A10i Imie Repait Done With Miracle Box... Here is Imie Repair Info... Code: 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM13) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x01D2000000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Checking IMEI DATA... IMEI1:359078060003764 IMEI2:359078060005769 Verify...Done. IMEI OK. Here is Pic... Br Haseeb Ur Rehman |
05-31-2017, 11:48 | #5 (permalink) | |
Freak Poster Join Date: May 2014 Location: Al-Bakistan
Member: 2191194 Status: Offline Thanks Meter: 75 | Quote:
