Old 04-14-2016, 07:07   #1 (permalink)
Member: 2394595
Thanks Meter: 24
Arrow plz add nand 6571 privicy reset
not supported yet from any tool even cm2
Operation : Format FileSystem [ v1.45 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1
DEV RID : F189720844574BF9232A0B60C57EAF09
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info! Make "Identify" first!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 04-14-2016, 07:53   #2 (permalink)
Member: 1128573
Thanks Meter: 242
yes bro, now biggest problem about NAND IC,
we hope and demand next update must be solve about NAND.
thanks
Old 04-14-2016, 08:05   #3 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,542
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:08
Hello,
Change Nand Setting From -> Setting SP -Other -> Nand Init Mode p1,p2
Old 04-14-2016, 09:26   #4 (permalink)
Member: 2394595
Thanks Meter: 24
yess all seting check here 1 by 1 but same
Old 04-14-2016, 09:28   #5 (permalink)
Member: 2394595
Thanks Meter: 24
this phone pending in my shop since 1 year
Old 04-14-2016, 10:06   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
What if make "read FW" with "NAND ext" enabled option?
The Following User Says Thank You to JayDi For This Useful Post:
Old 04-16-2016, 05:49   #7 (permalink)
Member: 2394595
Thanks Meter: 24
Operation : Read Flash [ v1.45 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Phone found! [ 9 ]
Sync...
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
[Read Ok] : preloader_hexing71_et_lca.bin
[Read Ok] : lk.bin
[Read Error] : Bad BOOT data
Looks like unusable file , break!
Done!
Elapsed: 00:00:27
Old 04-16-2016, 05:51   #8 (permalink)
Member: 2394595
Thanks Meter: 24
same error on all version
Old 04-16-2016, 08:02   #9 (permalink)
JayDi's Avatar
Member: 462970
Bad luck for that phone. Unsupported.
Old 04-17-2016, 14:59   #10 (permalink)
Member: 1957238
Thanks Meter: 80
for any nand mtk its simple and clear we all know that privacy lock is in userdata so just make a full backup of the same phone in scatter format then after format whole flash except preloader of that same phone. after that download backup with userdata unchecked using sptool but after process imei need repair unbeatable problem of privacy is gone. this solution tested on different chips mt6571/2/82.
The Following User Says Thank You to Kukuphilmur For This Useful Post:
Page generated in 0.16778 seconds with 8 queries
