03-26-2007, 09:37 | #6 (permalink) |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | I think his problem is: Infinity can't repair the phone which uses Samsung KAD060300B flash rom. P/s:With AMD/Spansion S71PL129JB flash rom,no problem at all. Am I right @halongmobile? :-) B/r |
03-26-2007, 09:54 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @hakima It's really strange situation: we are trying to understand what is the problem instead of simply get detailed description like this: 1. problem is: ..... 2. flash chip is: .... 3. problem only when: ..... etc. |
03-26-2007, 10:50 | #8 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | First of all,sorry for misunderstanding. I don't want to make a new thread with the same situation and that's why I post like that. Here is my errors description: I already tested some phone which has flash rom Samsung KAD060300B inside (MT6226 based).Phone can't be repaired after rebuild RPL file.So I decide to change flash rom with Spansion/Amd flash then rebuild with the same RPL(coz I did not change CPU so HW Id will not be changed).And after that,all of them were repaired. I'm so sure all of those Samsung flashes have good condition coz they can be rewrite with Up 1024 prommer and work like a charm in (MT6217 CPU base). At least,I hope you can understanding me now and will not think that I spamming and post bla..bla in your support forum. B/r |
03-26-2007, 11:49 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @hakima As about possible problems with flash chip. It can be 2 possible problems: 1. flash chip dead/semi-dead (hardware fault, need to replace flash chip) 2. problem with correct flash chip detection (software problem) in this case need to make this: 2.1. go to software "Settings" page and change "Advanced chip detection..." box on/off (check or un-check). 2.2. try now to write RPL again if still no luck: post log here so I can check what is the problem and probably I'll give an advice what to do. But for sure I can't give any advice if somebody say "problem exist with flash". What problem ? Where is the error ? What is problem reason ? Nobody know... So, I can't give exact advice in this case before I see detailed description. |
03-27-2007, 09:25 | #10 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: http://www.halong.vn/ Age: 33
Member: 45580 Status: Offline Thanks Meter: 48 | Quote:
03-27-2007, 09:39 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @halongmobile it's not hard for me to write the same one more time: http://forum.gsmhosting.com/vbb/show...29&postcount=9 if still no luck: post log here so I can check what is the problem and probably I'll give an advice what to do. |
03-27-2007, 15:46 | #12 (permalink) |
Insane Poster Join Date: Apr 2005 Location: china, cambodia, vietnam Age: 44
Member: 132968 Status: Offline Sonork: 100.1619307 Thanks Meter: 12 | I checked and repaired two mt 6226ba flash samsung. actually when I flashed samsung I just only wrote until flash 1 ( infi detect 2 flash chip ) and it showed error and I couldnt continue write. you should use chinese miracle 1.20 write flash . After write rpl ok, you put the button call and power at the same time - it will be OK This is Log. COM3 selected Device: Autodetect Checking data, wait... Action: Read information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: EC22E000000000 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb detecting chip[01] in region[00]... flash: EC22E000000000 flash: 33AB6800000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb total number of flash chip detected: 02 Initialize Done Set baud... 921600 Set baud Done Check space... operation mode: Fast detection mode device parameters autodetection in progress.. detecting chip[00] in region[00]... flash: EC22E000000000 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb detecting chip[01] in region[00]... flash: EC22E000000000 flash: 33AB6800000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb total number of flash chip detected: 02 total flash region size: 01000000 detecting eeprom area in 2 chip(s)... flash: EC22E000000000 flash: 29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: EC22E000000000 flash: 33AB6800000000 checking area[00800000]: 00000000-007FFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 01 eeprom area detected[00800000]: 00600000-007FFFFF detect device identification, method #1... detection phase #1... protocol version: 0004 2nd [enhanced] (or higher) generation model detected Attention: read full flash backup before any action ! warning: probably identification data damaged, power-on problem possible Probably identification data damaged, id: [0BB51E29] version: [M500TV_Y7_PCB01_GPRS_MT6226_S01.00_0.BIN_0ACB4A9D] Do you want to write RPL file (RPL file must be in current folder) ? flash: EC22E000000000 flash: 29EA0000000000 Write: rpl rpl write ok identification detection finished device-id: 0BB51E29 version sw1: M500TV_Y7_PCB01_GPRS_MT6226_S01.00_0.BIN version sw2: M500TV_Y7.00.0 detection phase #3... .................................................. .............. detect device parameters finished detecting languages... ................................ Err: can't detect language parameter #1 can't detect language names if software not respond/freez/failed now, make "Detect language names (slow process)" unchecked and repeat operation. file saved: backup_system_log_0BB51E29_ [M500TV_Y7_PCB01_GPRS_MT6226_S01.00_0.BIN]_0ACB4A9D_20070327- 181015.B0X.bin Finished, time used: 138 sec Remove/Install battery now ! COM3 selected Device: Autodetect Checking data, wait... Action: Read information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: EC22E000000000 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb detecting chip[01] in region[00]... flash: EC22E000000000 flash: F6811000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb total number of flash chip detected: 02 Initialize Done Set baud... 921600 Set baud Done Check space... operation mode: Fast detection mode device parameters autodetection in progress.. detecting chip[00] in region[00]... flash: EC22E000000000 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb detecting chip[01] in region[00]... flash: EC22E000000000 flash: F6811000000000 flash: AMD/Fujitsu std [0008x002000 007Fx010000] 8Mb total number of flash chip detected: 02 total flash region size: 01000000 detecting eeprom area in 2 chip(s)... flash: EC22E000000000 flash: 29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: EC22E000000000 flash: F6811000000000 checking area[00800000]: 00000000-007FFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 01 eeprom area detected[00800000]: 00600000-007FFFFF detect device identification, method #1... detection phase #1... protocol version: 0004 2nd [enhanced] (or higher) generation model detected Attention: read full flash backup before any action ! warning: probably identification data damaged, power-on problem possible Probably identification data damaged, id: [6BEE1E9F] version: [M503T_F5_PCB01_GPRS_MT6226_S01.00_0.BIN_ADE6B8AC] Do you want to write RPL file (RPL file must be in current folder) ? flash: EC22E000000000 flash: 29EA0000000000 Write: rpl rpl write ok identification detection finished device-id: 6BEE1E9F version sw1: M503T_F5_PCB01_GPRS_MT6226_S01.00_0.BIN version sw2: M503T_F5.00.0 detection phase #3... .................................................. .............. detect device parameters finished file saved: backup_system_log_6BEE1E9F_ [M503T_F5_PCB01_GPRS_MT6226_S01.00_0.BIN]_ADE6B8AC_20070327- 185203.B0X.bin Finished, time used: 117 sec Remove/Install battery now ! |
The Following User Says Thank You to tranchiemtai For This Useful Post: |
Plz check manole do every thing now able to write pm 1 and 309 | rajan nishchal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 15:20 |
BB5 rpl expert plz check my rpl file.. | Lior123 | Nokia Base Band 5 ( BB-5 ) | 0 | 10-27-2009 02:26 |
plz check this RPL !! | .::NaNTeC::. | Gsmfather The Wholesale Unlocking Database | 1 | 08-28-2008 09:04 |
PLZ check fw CM CPU 6226BA | halongmobile | Infinity-Box | 6 | 10-26-2007 15:01 |
PLZ check fw CM | halongmobile | Infinity-Box | 1 | 01-20-2007 11:50 |
