Old 01-01-2016, 16:30   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
[World First] Alcatel "Pixi First" SC7731 : Repair/FW/Service/Forensic!
Identify :
SLDR Load Ok
BB CPU  : SC7731
SC7731 Alcatel
For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab!
Operation : Check/Read Info [ v1.10 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 35 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Alcatel eMMC Loader
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : ALCATEL_ONETOUCH_4024D
Model Brand : TCL
Model Device: ALCATEL_ONETOUCH_4024D
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA_18045
CompileDate : 1442825396
Project Ver : 4024D_RU_AL_V1.8_150921
Model Ext   : 4024D
ExtraInfo : HWInfo not exists, normal phone
ExtraInfo : GSM Phone
Elapsed: 00:00:13
Reconnect Power/Cable!
Repair Security :
Operation : Repair Security [ v1.10 ]
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Write new security data :
IMEI1 : 999923232323234
IMEI2 : 999945445454548
Step #1 Ok
Step #2 Ok
Step #3 Ok
Write done!
Elapsed: 00:00:18
Read Firmware :
Just REAL, FULL , COMPLETE and WORKING firmware, which allow revive phones from ANY state
Operation : Read FullFlash [ v1.10 ]
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Step #1 Passed!
[FW_READER] : Step #2 Passed!
[FW_READER] : Step #3 Passed!
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : TCL
AndrVersion : 4.4.2
Model Ext   : 4024D
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem.bin
[Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.31.1_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x800.bin
[Read Ok] : fblogo_480x800.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : userdata.img
Firmware Size : 1242 MiB
Saved to : E:\SP7731GEA_18045_ALCATEL_ONETOUCH_4024D_4.4.2_4024D_RU_AL_V1.8_150921\
Done!
Elapsed: 00:11:00
Flash FW :
3 Minutes for get a result
Infinity SC Firmware Detected
FW Size : 1242 MiB
Load Ok!
Operation : Flash [ v1.10 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_modem_CP2_WCN_14E_W15.31.1_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:02:58
Forensic : PatternLock Read :
12 seconds for whole process from press button to get result.
Operation : Read PatternLock [ v1.10 ]
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Reading PatternLock ...
Read Ok , decrypt
PatternLock Sequence : 124789
Done!
Elapsed: 00:00:12
Forensic : PhoneBook Recovery :
Operation : Read PhoneBook [ v1.10 ]
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Mount : /data
Step #1
Step #2
Read Ok, PhoneBook records extracted : 6
TXT Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.txt
Write : 6
CSV Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.csv
Write : 6
VCF Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.vcf
Write : 6
VCFv3 Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook_v3.vcf
Elapsed: 00:00:20
Format FS/Reset Settings :
Operation : Format File System [ v1.10 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:19
The Following 22 Users Say Thank You to JayDi For This Useful Post:
Old 01-01-2016, 19:13   #2 (permalink)
Member: 2501288
Thanks Meter: 328
good work the best team
Old 03-07-2016, 16:59   #3 (permalink)
cavalierks's Avatar
Member: 1523083
Sonork: 100.1609029
Thanks Meter: 141
goood work
alcatel 4024d
read pattern
Operation : Read PatternLock [ v1.09 ]
3. Insert cable
Phone found! [ 62 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Read Ok , decrypt
PatternLock Sequence : 75963
Done!
Elapsed: 00:00:26
The Following User Says Thank You to cavalierks For This Useful Post:
Old 03-11-2016, 15:08   #4 (permalink)
Member: 447187
Thanks Meter: 107
hi, pls i need flash file for this phone.
Old 03-11-2016, 17:17   #5 (permalink)
JayDi's Avatar
Member: 462970
Hello. Check on support area.
Old 04-03-2016, 12:36   #6 (permalink)
Member: 2173641
Thanks Meter: 25
hi JayDi no flash file in support area
Old 04-04-2016, 08:46   #7 (permalink)
mquimpanes's Avatar
Member: 765233
Sonork: 100.1664273
Thanks Meter: 107
hi reading firmware need to root or not
Old 04-04-2016, 17:02   #8 (permalink)
Member: 2173641
Thanks Meter: 25
no need root ,,,,,,,,,,,,
The Following User Says Thank You to RYOAW For This Useful Post:
Old 04-08-2016, 22:29   #9 (permalink)
Member: 2309061
Thanks Meter: 10
can i unlock it with CM2SPD?
Old 04-08-2016, 22:48   #10 (permalink)
Member: 2309061
Thanks Meter: 10
really It is the first in the world .Thanks Infinity team !
Old 04-09-2016, 14:20   #11 (permalink)
JayDi's Avatar
Member: 462970
SPD module can unlock 95% of existing Generic SPD Android mobile phones/tablets on SC77xx/SC88xx/SC9xxx/SC57xx platforms.
The Following User Says Thank You to JayDi For This Useful Post:
Old 04-25-2016, 11:46   #12 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Unlock network
Unlock from network TELE2 KZ
Chinese Miracle II  [SPD module] v 1.16
Start  at : [25.04.2016 / 16:22:24]
Operation : Check/Read Info [ v1.16 ]
3. Insert cable
Phone found! [ 155 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : TCL
Model Device: PLAY_P1
AndrVersion : 4.4.2
CompileDate : 01.10.2015 9:28:31
Project Ver : 4024D_KZ_AL_V1.2_151001
Model Ext   : 4024D
Elapsed: 00:00:24
Finish at : [25.04.2016 / 16:22:49]
Start  at : [25.04.2016 / 16:23:49]
Operation : SP Unlock [ v1.16 ]
Mode : DirectUnlock
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
SimLock state : Locked!
Unlocking ...
Unlock Done!
Elapsed: 00:00:16
Finish at : [25.04.2016 / 16:24:06]
The Following User Says Thank You to Abzal For This Useful Post:
Old 04-25-2016, 13:13   #13 (permalink)
Registered User
Member: 2462860
Thanks Meter: 71
how about signal problem
s7731gea
Old 04-25-2016, 15:06   #14 (permalink)
JayDi's Avatar
Member: 462970
s7731gea
How about correctly explain and figure out CORRECT question?
Old 05-15-2016, 13:02   #15 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 332
Originally Posted by JayDi View Post
Identify :
SLDR Load Ok
BB CPU  : SC7731
SC7731 Alcatel
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : TCL
AndrVersion : 4.4.2
Model Ext   : 4024D
Elapsed: 00:00:13
Repair Security :
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Step #1 Ok
Step #2 Ok
Step #3 Ok
Write done!
Elapsed: 00:00:18
Read Firmware :
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : TCL
AndrVersion : 4.4.2
Model Ext   : 4024D
Done!
Elapsed: 00:11:00
Flash FW :
FW Size : 1242 MiB
Load Ok!
======= Flash
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Elapsed: 00:02:58
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Read Ok , decrypt
Done!
Elapsed: 00:00:12
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Mount : /data
Step #1
Step #2
Write : 6
Write : 6
Write : 6
Elapsed: 00:00:20
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:19
Please add SP Unlock for this current model.
We really need.
Page generated in 0.29833 seconds with 9 queries
