04-28-2016, 00:47 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Datawind UbiSlate 7DCStar (7DC*) MT6571 Flashing Error. This's Datawind UbiSlate 7DC*. There Is Many Version Of This Model Like 4GB & 8GB Also HW-ID Available. This Tab HW-ID : 0R06072AD83720. First I Read Firmware From Working Tab & Tried To Write On Dead Tab But Same Error. Then I Tried On Same Working Tab Which I Used First Time For Read It But Same Error. Operation : Check / Read Info [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026D1537F5913CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642026D1537F5913CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 695E4847F5A63D99DD2325603BFA38E2 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : roco ProdName : D705 ProdModel : D705 Device : D705 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.25 SECURITY : IMEI_SW [1] : 91149XXXXXXXXXX IMEI_SW [2] : 91149XXXXXXXXXX BTMAC Addr : 1099XXXXXXXX WiFi MAC : 000FXXXXXXXX MODEM : BaseBand : MT6571_S00_MOLY_WR8_W1315_MD_WG_MP_V64_1_2g_n EXTRA : LCD [0] : $(ROCO_CUST_LCM) LCD Res : $(ROCO_LCM_HEIGHT)x$(ROCO_LCM_WIDTH) TOUCH [0] : $(ROCO_TP) CAM [0] : $(ROCO_MAIN_CAM) CAM [1] : $(ROCO_SUB_CAM) MODEM : JOYASZ12D_TB_KK_GPRS LOCALE : $(ROCO_LANGUAGE) Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026D1537F5913CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642026D1537F5913CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 695E4847F5A63D99DD2325603BFA38E2 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : roco ProdName : D705 ProdModel : D705 Device : D705 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.25 [Read Ok] : preloader_d706_emmc.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6571 / V1.1.1 / d706_emmc / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 937 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6571__roco__D705__D705__4.4.2__ALPS.KK1.MP7.V1.25\ All done! Done! Elapsed: 00:05:59 Reconnect Power/Cable! Operation : Flash [ v1.47 ] Code: Scatter Load Ok , BaseBand : MT6571 , Project : d706_emmc , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : roco Device Model : D705 Device CPU : MT6571 Device IntName : D705 Device Version : 4.4.2 Device Compile : 2/26/2016 8:30:19 AM Device Project : ALPS.KK1.MP7.V1.25 Device ExtInfo : D705 Ready to Flash! Operation : Flash [ v1.47 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026D1537F5913CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642026D1537F5913CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 695E4847F5A63D99DD2325603BFA38E2 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6571 , Project : d706_emmc , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
04-28-2016, 20:07 | #3 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Yes Problem Solved By Uncheck HW. Operation : Flash [ v1.47 ] Code: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026E5430C60132B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642026E5430C60132B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : FD20E5B0C3F7C67DC922E04DCC574676 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6571 , Project : d706_emmc , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Disabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4124 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000004000000-0x0000000000100000 Erase : 0x0000000005D00000-0x00000001C7B00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_d706_emmc.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:40 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:01 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:10 Reconnect Power/Cable! Now I Have Issue With Repart User Memory. Operation : Repart User Memory [ v1.47 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026E5430C60132B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642026E5430C60132B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : FD20E5B0C3F7C67DC922E04DCC574676 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Available Internal Memory : 5,10 GiB Memory settings detected , waiting user decision Memory size set, initialize new settings Structure detection passed successfully Init passed! Power On phone to accept changes! Done! Elapsed: 00:03:05 Reconnect Power/Cable! Correct Me Please, Where I Did Go Wrong?. |
04-29-2016, 15:22 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I need original FW backup and FW after Repart Tool. Both zipped and in PM for further checking. There is much variants of old structure ( at lest known - 9 ) |
12-11-2016, 15:32 | #7 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | Datawind usbslate 7dc* Quote:
Dear Bro can you upload your readout file please!!! i need this rom urgent!!! | |
02-18-2017, 08:05 | #13 (permalink) |
Crazy Poster Join Date: Aug 2012 Location: kolkata
Member: 1800651 Status: Offline Sonork: [email protected] Thanks Meter: 20 | need UB ISLATE 7DC* MT8312DA firmware. HW-ID:0P06072AD83720 bord clr- blue bord versn- D705_MB_V2.0 camera id- LS1015-CS0432A-V1.0-F THANX IN ADVANCE.. |
02-25-2017, 09:34 | #14 (permalink) |
Member: 1800651 Status: Offline Sonork: [email protected] Thanks Meter: 20 | |
